weird noise and lights flashing
2007-05-18 by siobhan mcclory photography
Hi Steve,
Do you have a CFS system?  I had this problem when the ink lines were
too loose and when the the print head travelled all the way to left
(which is not on every pass)   they evidently were registered as
foreign object/blockage/threat to print head survival  (something
along that line of thought)  and the red lights came on blazing.  It
also made a fairly dreadful sound.  Took me a while to figure it out
and all it required was gently pulling the lines back.  There is a
very fine line between too tight and too much slack.  And yes a
power on & off cleared the problem until the printhead had to travel
all the way to the left again.
Hope this makes sense./  Siobhan
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steve Kale"
<stevekale@...> wrote:
 > Hi there
 > I am suddenly having a problem with my Epson 2100. Quite often now
(more often than not)
 > when I send anything to be printed it makes a horrible graunching
noise and then all the
 > lights flash red. A power off and on usually clears the problem but
is tedious. Any ideas? I'd
 > love an excuse to have the little 2400 next to my 4800 but perhaps
this issue is not so
 > terminal....
 > Thanks
 > Steve
Re: [Digital BW] weird noise and lights flashing
2007-05-19 by Steve Kale
No CFS
From: siobhan mcclory photography <siobhanmccloryphoto1@...>
Reply-To: <DigitalBlackandWhiteThePrint@yahoogroups.com>
Date: Fri, 18 May 2007 16:36:38 -0400
Subject: [Digital BW] weird noise and lights flashing
Hi Steve,
