opening an icm file
opening an icm file
2007-05-21 by cieloblu22000
Is there a way to open any icm file to see the settings it is sending
to the printer? And then can I make adjustments to that file and save
it as a different icm that I may like better or just want different?
Thank you,
Charlotte
RE: [Digital BW] opening an icm file
2007-05-21 by Eric Neilsen Photo
With appropriate software yes.
Eric Neilsen Photography
4101 Commerce Street, Suite 9
Dallas, TX 75226
214-827-8301
Skype : ejprinter
  _____
cieloblu22000
Sent: Monday, May 21, 2007 4:11 PM
Subject: [Digital BW] opening an icm file
Thank you,
Charlotte
Re: [Digital BW] opening an icm file
2007-05-22 by Steve Kale
There is an easy (and free) way to view the inside on an ICC (ICM) file.  If
on a Mac then open the file with the Colorsync utility and if on Windoze
then you can download a profile inspector utility from www.color.org.
Editing one requires appropriate software and can be done.  However, I
suspect that you¹ve got little to be gained from doing so versus simply
creating a new profile.
Organization: Eric Neilsen Photography
Reply-To: <DigitalBlackandWhiteThePrint@yahoogroups.com>
Date: Mon, 21 May 2007 18:03:37 -0500
Subject: RE: [Digital BW] opening an icm file
Dallas, TX 75226
214-827-8301
Skype : ejprinter
_____
<mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> ] On Behalf Of
cieloblu22000
Thank you,
Charlotte
2007-05-22 by Eric Neilsen Photo
Steve, Thanks for the reminder of the names for PC use. I have previously
worked with Profile Maker 4.1 suite and with that editor. You can spend some
time learning all about them and how to edit them, but as Steve suggest it
may make sense to just make a new one. Charlotte are you have a particular
problem with one? A canned profile or a self made, custom made?
Dallas, TX 75226
214-827-8301
Skype : ejprinter
  _____
<mailto:e.neilsen2%40worldnet.att.net> .att.net>
_____
Thank you,
Charlotte
Re: opening an icm file
2007-05-23 by Charlotte
Hi. Thanks for your replies. I was just wondering if opening an icm file and adjusting it is a good starting point when I am not satisfied with a profile. I have a 2400 and use the paper makers icm which is usually not completely to my liking. I can easily make adjustments in the ABW and save it for that paper. For other adjustments such as contrast, lightening and darkening a tone I use a curves layer adjustment in CS3 and save it with the papers name for future use if it is an adjustment I think will be useful in the  future. Clayton's, Paul's and this list's information have been very helpful. The information and process involved in the creation of an icm is a bit overwhelming for me and will take me a while to grasp it all,  if ever I do.
Charlotte
2007-05-23 by Tyler Boley
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Charlotte"
with a profile.
Actually that is a bit of a daunting task, and not something many
people recommend. You'd need special profile editing software, not cheap.
This is a bit confusing, a color profile is not really applicable to
use with the ABW epson printing system. THough you could select one in
the Print With Preview section of photoshop, it would have been made
for color printing and very specific settings in the color section of
the driver. Pretty much irrelevant for ABW use.
You'd need specific software to do so, and also a measurement device.
Additionally, if you are talking ABW use for B&W printing instead of
color, the only relevant profiles would be those you can make with
QTR's Create ICC. None of the others, including those supplied by
paper makers, would be useful with the ABW section of the Epson driver.
For use with the color section of the driver, even for B&W, "real" icc
profiles would be relevant and there are applicable commercial
solutions available. I suspect someone may volunteer a specific
recommendation.
Tyler
RE: [Digital BW] Re: opening an icm file
2007-05-23 by Eric Neilsen Photo
Charlotte,  If you have an extra $600 to spend and want to gain control with
a more straight forward supported approach, you can use the Print Fix Pro
Suite and make profiles for use in an RGB environment and it would give you
good results. If that is a lot for you, try looking into QTR ($50) and using
your flat bed scanner to make things that look and act like ICC profiles.
The "real" profile makers are into the thousands and take some time to get
good at interpreting data and are really good for high volume precise
printing houses. If you haven't been printing high quality ink jets for a
long time, let me suggest this as a path.
Find or make a 100 step gray scale and print it using your ABW setting and
paper. Save those that really make you happy both for range and color
issues; i.e. toning. It works well if you are used to looking at your prints
in a somewhat critical way for separation of scale and evenness of tonal
scale.
If you are trying to do color printing I have found that saturation and hue
are the two basic controls that help without custom profiles that really
work. Once again, QTR might help you down that path as well.
I have seen that the less money you spend, the more "fly by the seat of your
pants" skills are required to get it right. But you can get it right. The
products like Profile Maker 5 by Gray Tag will give you plenty of control,
maybe more than you need, but a good solid program package both for making
and editing profiles. The more sophisticated the product the more devices
you will be able to work with like printers, projectors, etc. It provides
you a visual 3D tool to inspect your profiles and allows you to see where
things are not fitting.
And just like there are PCs and MACs, not all profiling systems will talk to
each other and make data that can be read across the board. If you do go the
profiling route, realize that we have gone from 6 to 12 ink machines in a
short time. While we also had only extremely high priced profile packages to
work with and now there available to nearly ever serious amateur. Buy
wisely.
Eric
Dallas, TX 75226
214-827-8301
Skype : ejprinter
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Tyler
Boley
Sent: Wednesday, May 23, 2007 1:41 PM
Subject: [Digital BW] Re: opening an icm file
with a profile.
recommendation.
Tyler
2007-05-24 by Charlotte
Hi, Tyler and Eric. Thank you for taking the time to respond. I appreciate it.  My post was confusing. I print both color and bw. I am attempting to understand exactly what I am doing. I have followed Clayton's formula for BW printing and am now wanting to experiment. So I am attempting to understand what an icm,  paper profile and paper selection do.  And how I might manipulate these things. In color I have used Epsons standard paper setting with their papers. When I've used other papers I've had to make changes,for example magenta, etc. to get the print I want. When I use  the ABW in the epson I end up making the similiar adjustments for coolness, neutral and warmth. When I choose a paper Clayton hasn't given specific settings for I am not sure what I should do. I've read Paul's article on Making B&W Iccs w a flatbed scanner and have a very vague understanding at this point.  I am not sure what the paper setting tells the printer, what the icm tells the printer, what Paul's ICCs tell the printer and how those things are similiar or different and how I might manipulate these things to get what I want.
The papers I am currently experimenting with are the Premiere BW Matte paper and Moab BW Entrada.
Thank you.
