R200 less clog-prone than 1280? Another printer?
2007-06-14 by Peter A. Klein
I just wasted yet another evening and precious ink dealing with yet
another Clog From Hell on my Epson 1280 with UT2 inks.  I love the look
I get with the Neutral UT2 setting, and with BO/Eboni.  But I'm royally
fed up with the endless succession of periodic clogs and BO banding.
Here's a thought.  I have an R200 that I've been using for color.  What
if I reversed them?  Go back to color on the 1280, and get UT carts for
the R200.
Would this be OK, or would the 200 be just as clog-prone?  Would I be
better off with a printer designed for pigment ink? Any suggestions?
I use Picture Window Pro, not Photoshop, so I'd prefer to stick with
the EZ or Roarke curves approach rather than the embedded profile
approach. I'd even consider a non-Epson non-MIS approach.  More than
anything, I want reliability, reliability, reliability.
--Peter
Re: R200 less clog-prone than 1280? Another printer?
2007-06-14 by Chris Ellis
Hi Peter
I have a R220 which replaced a 1290.  I was (like you) spending whole
evenings unclogging the printer and sometimes managing to produce a
couple of prints.  It eventually succumbed to the (apparently fatal)
stuck nozzle problem so I decided to bin it.
The R220 is much better.  I have had occasional clogs but they're
quickly resolved by a quick head clean.  I've had it for at least a
year now.  I don't print that regularly.
Hope this helps.
Chris
2007-06-15 by Sergei Antonov
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Peter A. Klein"
<pklein@...> wrote:
than
> --Peter
You probably should look to something else than Epson R series
printers for reliability.
My R200 stopped working in one moment after about a year of
occasional printing. I used only MIS pigment inks in that printer.
One day I replaced UT7 inks by MISPRO, as I did several times before,
and didn't get a clean nozzle pattern. After number of clean up
cycles it still is not clean, and I suspect that either pump or wiper
is broken. Nozzle pattern is getting worse after clean cycle.
So, in my opinion, those printers are good while they work, but they
could stop working any moment. And that will leave you with
unfinished job and with all your investments into MIS carts, inks,
etc, that cannot be used on next generation.
I remember discussion about reliability related to cars. Lexus may be
the most reliable, but you could have a small fleet of Subaru for the
same money, and all together Subary will give you more reliability.
This way I would have to buy several r220 when they were at the
lowest price and with rebate, sell OEM inks and use them one after
another when they die.
Good luck,
Sergei
