album sleeves ???
album sleeves ???
2007-06-20 by helices
I have been printing a lot on Epson Premium Luster Photo Paper (S041405)
at 8.5"x11".
I want to create an album of these prints.
What are the best options?
In office supply stores, there are transparent "plastic" sleeves, with a
3-hole punched rib along one side.  This could be ideal; except, I
wonder whether or not the print side will eventually stick to the inside
of the sleeves, and destroy the prints.
What do you think?
Best Regards,
helices
Dare to fix things before they break . . .
Our capacity for understanding is inversely proportional to how much
we think we know.  The more I know, the more I know I don't know . . .
Re: album sleeves ???
2007-06-20 by alistair_owens
Personally, I am not a fan of these plastic sleeve arrangments. Not
enough space around the image and the plastic degrades the production
quality. I much prefer a nice white(ish) acid free dry-mount large
enough to allow plenty of space around the image.
Re: [Digital BW] Re: album sleeves ???
2007-06-20 by Richard Smallfield
I use 'Colby' folders and sleeves made of archival polypropylene - but they really hit the dmax and colour saturation badly - you have to take the pictures out of the sleeves to really see what they look like.
However, polyester sleeves are very clear and, if you can afford them, really show off your work well.
I don't know however, how they fare with sticking to lustre papers.
Not much help, perhaps, but I thought I should let you know what I've found.
Richard
http://smallfield.vze.com
http://photos.smallfield.vze.com (Photos web site)
http://warkworth.vze.com/ (Warkworth photo essay)
http://picasaweb.google.com/rsmallfield/ (Recent work)
   "Programming is an endless race between the software engineer,
   who seeks to design increasingly idiot-proof code, and the Universe,
   which strives to produce even bigger idiots."
   --anon
Re: [Digital BW] album sleeves ???
2007-06-20 by jim kitchen
Dry mounting is the best option, followed by a protective
sleeve distributed by Clearbags, where the archival sleeve
fits the mounted image.
If you encase a mounted image in a plastic sleeve, or
any other suspect material, you are doing a disservice to
your finished work, where the chemicals in the plastic
material will jump to your image, and the inherent supply
of chemicals within the plastic material will eventually destroy
your finished work.
The manufacturer of these archival sleeves has the best solution.
Look for Clearbags on the net...
jim k
2007-06-20 by Debbi
(newbie question) Is dry mounting putting it in a mat?
Debbi
>your finished work.
>jim k
2007-06-20 by ann clancy
dry mounting is a process which attaches the image to a matt board using heat and a special treated sheet of "glue".  Then one can put a window over the mounted piece creating protection within a frame.
  ann
Debbi
>your finished work.
>jim k
Take the Internet to Go: Yahoo!Go puts the Internet in your pocket: mail, news, photos & more.
2007-06-20 by Debbi
Do most of you do this process yourself or have it done?
(Thanks Ann)
Debbi
>   ann
>Debbi
>>your finished work.
>  >jim k
Debbi, when I first suggested dry mounting I just meant the old style
archival photo albums that have black or white pages. Apart from
some  type of tissue paper between the pages to prevent facing photos
sticking together, the image is not viewed through any covering and
thus can be seen in all its glory.
The term dry-mount refers to the fact that the photo is attached to
the page using some form of dry (and detachable) adhesion. I either
use corners (which can look rather good) or a removable adhesive
patch called "Magic Dots".
An image presented in this way in a good quality album with plenty of
space surrounding it, while not quite as good as matt-mounted, does
present the image well.
Hope that makes sense.
regards
Alistair
> Debbi
2007-06-20 by Debbi
Yes, I understand, I didn't mean to hijack this thread from helices.
I though they were asking a good way to store away images, yet an
easy way to view them (an album). I was also considering the
transparent sleeves, now I will contact clearbags as mentioned by
someone.
>regards
>Alistair
>  > Debbi
Debbi,
  i do it myself as i have the equipment, but you can have it done at almost anyplace that does framing.
  ann
(Thanks Ann)
Debbi
> ann
>Debbi
>>your finished work.
> >jim k
Need a vacation? Get great deals to amazing places on Yahoo! Travel.
