1280 printer doesnt like the cartridge
2007-06-23 by rebphoto
Hi Gang............. Here is the problem............ I am using an Epson 1280 with MIS UT2 Ink. It stopped recognizing the Black Ink Cartridge. I refilled it and tried to re set with the MIS Chip Re setter. The re setter kept telling me that the chip was corrupt. I just got some new empty spongeless cartridges from MIS, I put ink in them and the printer keeps telling me that the cartridge is not installed in correctly. I took a G&G black ink cartridge and it tells me the same thing. I have been using the UT2 ink in this printer for about a year now and up till now it has worked great. Is there some sort of re setting I need to do to the printer or do I need to clean the contacts on the printer? I have a job due and I need help in a hurry! Thanks Russ R.E. Baker Photography rebphoto@... Feed a Cat... Starve a Fever........ [Non-text portions of this message have been removed]
