Digital 'contact prints'
2007-07-16 by Sarah Thompson
Firstly, thanks to the people who responded about my lack-of-neutral
tone problem with my r2400 ABW prints -- it did turn out to be a flaky
light magenta cartridge. Swapping it out helped a fair bit, but wasn't
perfect. Then, I moved house, which involved packing everything up,
putting it in a truck and driving about 40 miles. On trying again, the
prints were perfectly neutral, so I therefore recommend moving house as
often as possible as a means of maintaining consistent print quality. ;-)
Actually, what I really wanted to write about is some experiments I've
done recently. I read a few articles online about problems with the
default interpolation algorithms used by both Photoshop and the Epson
drivers when rescaling images to the driver's internal 720ppi
resolution. I was thinking about doing some experiments with various
interpolation algorithms, then it occured to me, why not just print the
actual *image* at 720dpi? This means that no interpolation will occur
other than that which is purely part of the driver's dithering
algorithm. I realise that for many people this would result in prints
that are too small, but I am lucky enough that my two cameras have
4000x4000 and 8000x6000 resolution (a Megavision E4 monochrome
medium-format back and a Better Light large format scan back
respectively). Anyway, I tried it with a few images and was blown away
with the results -- the prints (made with the Epson driver in ABW mode,
Photo RPM, Epson Premium Glossy) are astonishingly sharp, if anything
more so than a large-format contact print (hence the title of the post),
with a level of three-dimensionality that I've never really seen before.
A (medium-format) photo taken a few months ago in Yosemite Valley from a
bridge over one of the streams shows incredibly fine detail in the
foliage. I also printed a couple of Better Light images shot in the
Mojave desert in Joshua Tree National Monument (roughly letter-size)
where every grain in the sandstone of a large boulder was clearly visible.
I think these days there is a real push toward ever-larger prints, but
some of the best images I've ever seen were actually really quite small
by modern standards (I'm thinking here of some original prints by Edward
Weston, who was very much into the contact printing approach).
Anyway, just thinking out loud, and wondering if anyone else had tried
the same approach.
[s]
Re: Digital 'contact prints'
2007-07-16 by Tyler Boley
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Sarah Thompson
<sarah@...> wrote:
> ...then it occured to me, why not just print the
> algorithm.
bingo!
> the same approach.
yes, with the same result. Thinking of doing a body of work this way
with imagery suited to the smaller prints.
Where's the time?
Tyler
Re: [Digital BW] Digital 'contact prints'
2007-07-16 by Michael King
Sarah,
Did you print with "Finest detail" checked in the print dialog?
In my tests it only prints @ 720 when finest detail is checked, otherwise it
downsamples to 360, presumably to keep the processing time and spool size
down.
Mike
> the same approach.
> [s]
Michael King wrote:
> Sarah,
> down.
I can't remember seeing a finest detail option -- where is it? Are you
using Mac or PC?
Sarah
on PC you get to it by clicking the advanced button on the first tab.
That takes you to the tab where you can set up various parameters for ABW
including tint and
"Finest detail".
Mike
>   Michael King wrote:
> > Sarah,
> otherwise it
> size
> > down.
> using Mac or PC?
> Sarah
Hmm... am I being blind? I still can't find it:
http://files.support.epson.com/htmldocs/r2400_/r2400_rf/images/g12w_04.gif
Sarah
> including tint and
> "Finest detail".
> Mike
>>   Michael King wrote:
>>> Sarah,
>> otherwise it
>> size
>>> down.
>> using Mac or PC?
>> Sarah
RE: [Digital BW] Digital 'contact prints'
2007-07-16 by Alan Kearney
No, your not blind. Epson "hides" this option. So here's how I get to it.
From Photoshop I select Print w/Preview, after checking the settings I
select Print. Some times I'm told the paper is larger than the printer - I
just click "Proceed", next I have to select which printer I'll be using
(I've got 4 to select from in the Print Window) > Select Epson Stylus Pro
4800 (your's will be R2400(?). Next click on the "Properties" button which
brings up the Epson Stylus Pro 4800 Properties screen, here's where you'll
see 4 tabs but NO Advanced button on the first Tab YET.
So next I have to select a paper or Custom setting that works with ABW, I'll
select "Watercolor Paper - Radiant White" to print on the Hahnemuhle paper
I'm using right now (just match this selection to your printing/paper
needs).
Selecting this kind or paper or selecting the "Custom" Radio Button about
1/3 down the first tabs surface, sort of middle - right of the page. Either
action will finally display the Advanced button (quite large, just below
"Custom Setting").
From here you have to select Advanced B&W Photo and you'll have a ton of
options to choose from!
Hope that helps. If not send me you direct email address and I'll take
screen shots to send to you.
Good luck, Alan
alan_kearney@...
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Sarah
Thompson
Sent: Monday, July 16, 2007 2:39 PM
Subject: Re: [Digital BW] Digital 'contact prints'
http://files.
<http://files.support.epson.com/htmldocs/r2400_/r2400_rf/images/g12w_04.gif>
Sarah
> including tint and
> "Finest detail".
Txs Alan as I was scratching my head trying to figure out what was going on.
Also Sarah you can download a resolution test image from this link that will
show you what resolution you are really printing at.
http://www.ddisoftware.com/qimage/quality/
Mike
> it.
> I'll
> needs).
> Either
> "Custom Setting").
> Good luck, Alan
> alan_kearney@... <alan_kearney%40sbcglobal.net>
> _____
> From: DigitalBlackandWhiteThePrint@yahoogroups.com<DigitalBlackandWhiteThePrint%40yahoogroups.com>
> [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com<DigitalBlackandWhiteThePrint%40yahoogroups.com>]
> On Behalf Of Sarah
> Thompson
> To: DigitalBlackandWhiteThePrint@yahoogroups.com<DigitalBlackandWhiteThePrint%40yahoogroups.com>
> http://files.
> Sarah
> ABW
> > including tint and
> > "Finest detail".
2007-07-17 by Sarah Thompson
> Mike
I think there must be a slight difference between the 2400 and the 4800
drivers -- I couldn't get that particular option to appear whatever I
did. However, I reproduced my printing procedure with the Qimage test
image as you suggested, and it seems that the r2400 was printing at
720ppi after all. You can clearly see the difference between the 720 and
the 360ppi tests, particularly in column D, so I think it's pretty much
proven. One thing that I would say, though, is that in column A, you
can't actually resolve adjacent lines, so whilst the ppi is clearly 720,
I have my suspicions that the real optical resolution as seen in the
final print is probably closer to 360, but if you're printing from an
image that's come from a Bayer pattern sensor, printing at 720 will
match this pretty much exactly. Since my images aren't
Bayer-interpolated at all, it might make more sense for me to be
resampling the image exactly 2:1 in each axis, so the Nyquist limit of
the image will match the Nyquist limit of the printer. Hmmm... I shall
have to try that...
Actually, I've probably answered my own question here -- adjacent black
and white lines are actually *exactly* on the Nyquist frequency, so
clever DSP algorthms responsible for the dithering are probably going to
brick wall below that frequency in order to avoid aliasing (i.e. visible
pixellation). Since the frequency limit of an image sourced from a Bayer
sensor is actually f/4 for red and blue and a bit more for green, this
should all be comfortably under the true Nyquist limit.
[s]
2007-07-17 by bwinkjet
I can find it.  My question is why check it for traditional
rasterized files?  Epson states it is for use with print or vector
images to sharpen straight lines.  Does it help or hinder when
checked and used with raster files of landscape, portraits,
paintings, etc.?
.gif
> Sarah
tab.
for ABW
> > including tint and
> > "Finest detail".
> > Mike
> >>   Michael King wrote:
> >>> Sarah,
> >> otherwise it
spool
> >> size
> >>> down.
Are you
> >> using Mac or PC?
> >> Sarah
