Proper Method for Measuring and Interpreting Ink Separation
2007-07-25 by jturner4210626
I'm a real newbie on this so any help would be greatly appreciated. I am attempting to
setup QTR on my system with my Eye One following the calibration guide. I have an Epson
2200 using EEM and stock UC inks.  I printed an ink separation page set at 100% and let it
dry overnight. I've downloaded Profilemaker 5.08 and configured my Eye One Pro for
reflection with spectral checked. When I bring up the spot measurement window, I have
the following settings:
Colometric
Color Space - Lab
Observer angle - 2 degrees
Illumination - D50
Delta E
Sample checked
I am at the point in the process where I am trying to discern the hardware ink limit for the
printer.  Rather than trust my eyes, I'd prefer to measure it. It's at this point that I'm
confused.  Do I start measuring at 50% and work my way up the chart and if so, what am I
looking for?  If I perform several readings, I get the following:
50% - 22.4
70% - 20.3
80% -17.6
85% -17.0
90% - 16.7
Do I conclude that I've reached maximum at the 85% level as there is not much of a
difference between 85% and 90%?
Thanks.
--Joel
Re: Proper Method for Measuring and Interpreting Ink Separation
2007-07-25 by Sergei Antonov
Joel, in my practice, L is increasing after you are reached the
minimum. When you have too much inks, DMax is getting lower. So keep
measurements until you see values increasing. You may do multiple
readings averaging the value.
Sergei
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "jturner4210626"
> 50% - 22.4
> 70% - 20.3
> 80% -17.6
> 85% -17.0
> 90% - 16.7
is not much of a
> Thanks.
> --Joel
Sergei,
If I understand you correctly, are you implying that if my 95% measurement is above 16.7
than 90% is my ink limit?
Are you aware of a formula to convert L to Density to determine dmax?
--Joel
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Sergei Antonov"
> Sergei
> > 50% - 22.4
> > 70% - 20.3
> > 80% -17.6
> > 85% -17.0
> > 90% - 16.7
> is not much of a
> > Thanks.
> > --Joel
2007-07-26 by Sergei Antonov
Yes, if 90% is your minimum L, then it is the ink limit.
There is number of calculators online that could do the conversion.
Recently one was referenced on this forum, make a search to find.
You actually don't need density, QTR could take L as you measure it.
--Sergei
