Hi Duane,
Thanks for your answer, I know that I'm on a difficult area and I
thing that I've to fix my problems step by step.
First try to find a way to have no more red cast when scanning a IT8
target print on paper with OBA. To try to have a good result with
color printing.
Any advise are welcome.
Then I'll dig more for my B&W/Color photos.
About QTR, Thanks for the advise, it is not the first time that I
ear that it is possible to print color with it. But I don't know
how, I'll dig more, try more.
About calibration device, I'm thinking about buying a PrintFix
package with its spectrocolormeter but I do not have enough
information about this device yet. I'm afraid to go for it and ear 2
month later "it is not the right tool, you should get this". It is
exactly the issue with my actual equipment.
Any feedback is welcome.
I don't what is PGP but I'll investigate.
You see Duane I'm still confident but know that it is a tough
journey. And Advise about ideal material
here I'm afraid by the
price.
Thanks and best regards
Daniel
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "dlruckus"
<dlruckus@...> wrote:
> Hi Daniel. I'm afraid you have picked a most difficult area to deal
> with. Using a scanner to profile paper and inks to your printer for
> color is difficult enough though marginally possible. However the
> difficulties exponentially expand when trying to balance colors
over
> the neutral and near neutral tones. Even using a spectro with
profile
> software to do this is very very hard. The PGP spectro package
spoken
> of here by some apparently has special functionality set up to do
this
> very thing and is well spoken of. It also would greatly enhance
your
> color profiles as well. (Note that I do not use one and have no
> financial interest in the plug.)
> Another method you might try is to use QTR's capabilities to
> accomplish the same thing. You would need to learn how to use QTR's
> curve creation capabilities and blend in colors to get your toned
> B&Ws. That can be done. In all events, it will be some work on your
> part to accomplish what you need.
> Sorry if this isn't good news for you. Most of us at one time have
> been down the road you are traveling.
> Regards
> Duane
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Daniel
Bourgade"
> <d.bourgade@> wrote:
> > Hi every body,
> > I'm a news comer in this group that has been recommended to me,
> > after a first reading of some topics I'm sure that someone in
this
> > group will be able to help me.
> > I'm working at the calibration of my color workflow, my tools.
> > Soft: Monaco EZ color
> > Screen prob: Optix XR
> > Scanner : Epson Perfection 4490
> > Printer ; Epson R2400
> > My problem:
> > When I'm doing my profiles for paper/ink combination using my
> > scanner, the profile gives a magenta cast to my grey scale. the
> > Print after calibration is thus magenta (red) and a little to
dark.
> > Is some one experience the same problem, and more of all found a
> > solution?
> > The problem is the same for the color printing.
> > X rite tells that the OB of the paper is the reason but does not
> > give solution. (actually my tests with other paper gives similar
> > results)
> > Of course I'm using QTRip for full B&W photos and the result is
> > perfect.
> > BUT, I'm doing photos in B&W with only one object having one
color
> > in it. So, I've to print in color mode.
> > Any help and/or experience on these subject are more than welcome
> > Thanks in anticipation.
> > Best regards.
> > Daniel
