Help with Con K7 inks and 2200
2007-08-20 by Chris Dollar
I just started using / experimenting with a set of Con's K7 inks on an Epson 2200 printer. I
actually ordered the split tone version of the inks. The gamma on the prints don't match my
monitor unless I adjust the gamma in QTR to about 8. I created a monitor profile manually
with Adobe Gamma. I do not have a color profiling system. Cam anyone give me a bit of
direction?
Re: Help with Con K7 inks and 2200
2007-08-20 by Tyler Boley
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Chris Dollar" <dcdollar@...>
printer. I
my
manually
> direction?
if I recall, when using the Cone profiles properly with QTR you do not alter the gamma or
other adjustments in the driver. I watched as at least 6 people on different computers,
both Macs and PCs, made print after print that matched their monitors from K7 split w/
QTR.
All FIles were edited and previewed in a 2.2 gray space, for which the profiles were
designed.
I also just watched as two photographers installed a K7 set in a 7800 and QTR for the first
time, and imediately began making prints to match their monitors, totaly problem free.
One used a dslr, the other grainy 35mm film. The new prints were set next to their
previous prints of the same images made with the ABW driver before the ink change. The
improvement was dramtic.
All instructions and settings need to be followed precisely.
I'd ask here-
http://tech.groups.yahoo.com/group/QuadtoneRIP/
and here
http://tech.groups.yahoo.com/group/piezography3000/
Probably more people using that system there.
Tyler
2007-08-24 by pglombick
I had no problem when I installed K7 inks in my R2400, except at first
when I picked the wrong printer model by mistake (Quad2400 instead of
Quad2400-K7). I also hads some ink leaking onto the margins. But it
looked wonderful on the first print.
On my R300 on the other hand, the results were disappointing to say the
least. I probably need to make my own profiles.
