R1800 or 2200 better for use with Piezo K7 inks?
2007-08-23 by pglombick
Your advice is most appreciated. I need to choose between the two in a
hurry. I have had good results with a R2400, but want to use K3 inks on
semi-gloss papers and my wife likes to print color.
I tried Piezo K6 neutral inks in my R300, but have problems with
banding, paper feeding, and I don't like to be limited to 8.5" wide.
Your choice and rational appreciated.
Re: R1800 or 2200 better for use with Piezo K7 inks?
Can someone help me out here?
My thinking is as follows. The R1800 might be better, as it has an
extra ink cartridge, thus making room for the pink cleaning solution to
prevent clogs. Also, I belive the R1800 has a higher resolution and 1.5
picolitre drop size compared to the 4 picolitres drop size of the R2200.
Then again, until you actually see the results, you never know. There
are also factors like clogs, paper feeding issues, etc. to consider.
This is the sort of information only long-term users can provide. I
have the opportunity to buy a used R2200 for a great price, but I'm
wondering if I should wait for a R1800 instead. Keep in mind, this is
purely for use with Piezo NK7 inks.
2007-08-23 by Jeff Randall
IMO, the extra ink position of the R1800 should not influence your
decision. In fact it is just one more extraneous thing to deal with.
A cleaner cart will only keep the jets associated with the cart
position clean.  It won't keep the entire head clean. So why bother?
The smaller drop size is very important if you are using Paul
Roark's 3-Eboni Black only workflow.  The larger drop size should
not affect the smoothness or ink drop visibility of the K7 prints.
Jeff
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "pglombick"
solution to
and 1.5
R2200.
2007-08-23 by Terry Ritz
Another consideration might be the upcoming gloss version of the K7
inks. Glop is added to the mix, so the extra 1800 position would allow
7 dilutions plus glop. The 2200 would still work, using 6 dilutions
plus glop, but the 1800 gives you more options.
In my case I use a common K plus 3 Sepia and 3 Neutral K7 ink. Works
fine in my 2200 right now but I'll be one ink short when gloss is
available.
Terry.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Jeff Randall"
> Jeff
> solution to
> and 1.5
> R2200.
2007-08-24 by pglombick
Thanks for the feedback.
I forgot about the upcoming gloss option and ended up getting the R2200
based on price. I had an old R300 lying around and I tried using a
Piezo (K6) ink, but I had problems with banding and a grid-like pattern
that Was still visible with the naked eye even at 2880. I tried
different dithering patterns, but it didn't solve the problem.
2007-08-24 by Steven Karafyllakis
with.
I've gone through 4 of these machines, and none of them had more than
3 ink channels that printed completely banding-free. One of them was
the gloss channel, so I've used it for that critical LK in a K4 all-
in-one configuration. I don't see having an extra channel to choose
from aa a liability. OK, if you're going for a single tone, matte-
paper solution, you don't need it, but OTOH having the option of
setting it up with A) matte K4, B) Gloss K3, and neutral, cold,
carbon, or deep sepia variations of either, has a great deal of
appeal to me
Steve Karafyllakis
> Jeff
an
> solution to
> and 1.5
> R2200.
2007-08-24 by Jeff Randall
Steve:  I agree 110% about the general fleibility of the R1800, but I
was focusing on the Piezo K7 inks only question.  I've got two R1800s
and love them -- they are great BW experimental platforms.
2007-08-26 by Steven Karafyllakis
With 6 or 7 inks being laid down, I seriously doubt you could tell the
difference between the two.
Steve Karafyllakis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Glombick"
> Yes, but does the smaller drop size make for better prints over the
2200?
