Epson R200 with Ultratone 3D?
2007-08-28 by marko.mili
I can get unused R200 locally to get me started with B&W printing. One
thing that is not clear to me is whether R200 can be used with UT-3D
inks (it seems that this would be the best choice of inks for
versatility and for learning).
Can I use R200 or should I try to find R220?
(I have PrintFix PRO for profiling, if that makes a difference)
Thanks.
RE: [Digital BW] Epson R200 with Ultratone 3D?
2007-08-28 by Paul Roark
I used the UT-3D regularly on an R220.  See
http://www.paulroark.com/BW-Info/UT-3D_Readme.pdf   So, in the abstract, the
inkset should perform well on the R200, but I can't say whether the 220
profiles will be well matched to the 200.  I've never tested that.  My guess
is that the curves may need to be re-linearized.  See
http://www.paulroark.com/BW-Info/Embedding_Photoshop_Curves_in_ICCs.pdf for
the basic procedures to do that.
The UT-R2 inkset is one you might want to consider, particularly if you're
just starting to get into B&W digital printing.  See
http://www.paulroark.com/BW-Info/R200_R2_Readme.pdf
Good luck with the system.
  _____
marko.mili
Sent: Monday, August 27, 2007 4:44 PM
Subject: [Digital BW] Epson R200 with Ultratone 3D?
Thanks.
Re: Epson R200 with Ultratone 3D?
I am trying to understand drawbacks of using UT-3D inks on R200...
Benefits seem to be many, such as not having to switch cartridges for
glossy/matt, and having ability to relatively easily create icc
profiles with PrintFix PRO. I realize it is not as plug-and-play, but
I don't mind tweaking - I enjoy it - for as long as ultimate results
are possible.
Are there any inherent drawbacks in UT-3D image quality compared to
using UT-R2 inkset on R200?
Also, I see that there are light black inks in UT-3D inkset for 7 or 8
color printers. Does this make a big difference compared to using 6
color printers like R200?
I guess I am flapping around a bit since I have no point of reference
- I only know what B&W prints from my Canon IP4300 look like, and what
real B&W prints look like, but I don't know what problems Ultratone
prints suffer from. For example, can you get perfectly smooth shadow
detail without visible posterization or grainines? The ip4300 I'm
using looks OK from 3ft away but not good enough up close. 10% and 20%
gray look smooth, but 15% gray is a little grainy, so when you have a
transition between these shades it just doesn't look good enough up
close - the texture changes. Do UT-3D inks suffer from similar
problems on Epson 6-color printers?
Marko
abstract, the
My guess
for
you're
> Paul
>   _____
> marko.mili
> Thanks.
RE: [Digital BW] Re: Epson R200 with Ultratone 3D?
Hi Marko,
>cartridges for glossy/matt, and having ability to relatively
>easily create icc profiles with PrintFix PRO.
>ultimate results are possible.
>compared to sing UT-R2 inkset on R200?
The R2 is mostly just easier.  If you enjoy the working the controls and are
comfortable with Create ICC-RGB (in QTR), then I'd go with the 3D.  It is
considerably more flexible and there should be no quality difference.
>for 7 or 8 color printers. Does this make a big difference
>compared to using 6 color printers like R200?
I dislike the LK and LLK inks in the 7 and 8 ink printers.  In fact, I
pulled the recommendation for the inkset and the 2400.  The Epson driver's
gray substitution in the 2400 made it very hard to profile.  The inkset
works best in 6 ink printers when the Epson driver is used.
>... I don't know what problems Ultratone prints suffer from.
Yes, that should be no problem.  Nothing is perfect in the sense that if you
enlarge the prints enough you'll see some dots, but they are not, I
believer, visible without a loupe.
>The ip4300 I'm using looks OK from 3ft away but not good enough
>up close. 10% and 20% gray look smooth, but 15% gray is a little
>grainy, so when you have a transition between these shades it
>just doesn't look good enough up close - the texture changes.
I don’t have a Canon printer, but from what you've said, I doubt it is can
compete with these dedicated inksets.  When used properly, the Epson printer
+ B&W inkset approach works very well.
abstract, the
My guess
for
you're
> Paul
> _____
> marko.mili
> Thanks.
