Printfix Pro v2, b&w .icc profiles and Epson ABW
2007-08-27 by Jean-Marc Humbert
Dear all,
My tools : Epson 3800, PrintFix Pro v2.1, PSCS2, QTR, calibrated Eizo
screen.
I am fan of B&W and just bought the 3800! What a fantastic tool!
My favorite papers are semi gloss (such as Hahnemuhle Fine Art Pearl)
since IMO the blacks are richer and deeper than with the fine art
papers (I use also Hahnemuhle Photo Rag).
Now of course I would like to fine tune my settings with the 3800 and
I very carefully studied the excellent workflows described by Eric
Chan
(http://people.csail.mit.edu/ericchan/dp/Epson3800/printworkflow.html)
 and Giorgo Trucco
(http://www.outbackphoto.com/printinginsights/pi045/essay.html).
My first conclusions :
with no specific profile, the results with B&W pics printed on FAP
are really better with the Epson ABW mode (set to dark, 2880dpi and
semi gloss paper) than when using the Color mode (all my files are
RGB/16bit); with the color mode, I loose all details on the deepest
shadows and the transitions are poor.
With the PrintFix Pro (v.2) software and the Colorvision
spectrocolorimeter, the profile I have made for Fine Art Paper does
make a real improvement for the color pictures, still not for the B&W
ones (Epson ABW mode is still better with respect to the deepest
shadow details).
Following Chan's and Trucco's recommendations, I did the following to
optimize b&w prints on FAP paper:
-          I printed a 100-step gray scale (as provided by Roy
Harrington with QTR) using the Epson ABW mode (dark, 2880 dpi) : I
noticed visually that there was a huge gap between the 100% black and
the 99% (confirmed by the readings of density from 2.06 to 1.70)
-          I read the 100 patches (plus 1 for the 100% white) with
the PrintFix spectro using the "measure" menu (which gives in a txt
file the Lab readings)
-          I converted the txt file using QTR Create ICC.exe to
obtain an .icc profile.
Now, I am blocked! How can I use such profile (I put it in the
relevant windows folder) to print a picture under Photoshop using the
same settings as for the 100-step gray scale? Indeed, how can I apply
such profile to print going through the Epson ABW mode (I had to
check "lets printer determine the color" to be able to print through
the ABW mode; if I apply the profile in the "Print with preview",
then I will have to check the "no color management" option in the
Epson driver and use the color mode.)
I must have missed something…! In both above mentionned workflows,
their authors mentionned that you may use the .icc profile obtained
via a spectrophotometer/colorimeter to "soft prove" and "print".
What I did (certainly wrongly) to move forward : I applied to my file
the profile (using the photoshop "convert to profile" option) and
then printed through the ABW mode : the result was really not
satisfactory with all my deep shadow details converted to 100%
blacks.
The question I have is according to these workflows, how can I use
this profile and still go trough the ABW mode to print. The question
is not about neutrality but about linearization (when I see the 100
step gray scale, I see the need to have a better transition in the
100% to 95% areas).
Thank you for your contribution and your help.
Jean-Marc Humbert
Paris, France
Re: Printfix Pro v2, b&w .icc profiles and Epson ABW
2007-08-27 by Manuel Toledo
I think that, when using ABW, the profile is used for soft-proofing
only. With it you can view the way the image should print (and thus
make adjustments so that it prints the way you want) prior to printing it.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Jean-Marc
Humbert" <humbertjm@...> wrote:
> Dear all,
> screen.
> Chan
>  and Giorgo Trucco
> shadow details).
> blacks.
> 100% to 95% areas).
> Jean-Marc Humbert
> Paris, France
Re: [Digital BW] Printfix Pro v2, b&w .icc profiles and Epson AB
2007-08-27 by Michael King
Hi Jean-Marc,
You use the creat icc profile, just like you would a colour profile to soft
proof and print.
You set photoshop to "let photoshop manage colour", but you also set the
printer's set up to ABW with the same settings you used to create the
patches.
Mike
On 27/08/07, Jean-Marc Humbert <humbertjm@...> wrote:
>   Dear all,
> screen.
> Chan
> and Giorgo Trucco
> shadow details).
> I must have missed something�! In both above mentionned workflows,
> blacks.
> 100% to 95% areas).
> Jean-Marc Humbert
> Paris, France
Re: [Digital BW] Printfix Pro v2, b&w .icc profiles and Epson ABW
2007-08-28 by Daniel Bourgade
Bonjour Jean Marc,
  I cannot help you for this (sorry!), but may be you can help me.
  I'm using Epson R2400, QTR, PSCS2, and calibrated ViewSonic screen with MonacoEZ.
  I'm about to buy a PrintFix Pro but I'm wondering if it bring much, I've made a big mistake buying the monaco system with printer calibration through scanner, and I do not want to make the same mistake another time.
  Also, I tried to go to "QRT create ICC" for investigation but I could not understand what to do as there is no interface screen. Do you know an address where I could find information about it, or if you have information to give.
  Thanks for your help.
  A+ Daniel
  En Francais c'est aussi possible (Je suis Francais vivant a ShangHai)
          Dear all,
screen.
Chan
and Giorgo Trucco
shadow details).
blacks.
100% to 95% areas).
Jean-Marc Humbert
Paris, France
Choose the right car based on your needs.  Check out Yahoo! Autos new Car Finder tool.
2007-08-28 by Eric Chan
To print using an QuadTone RIP ABW profile, set Photoshop's Color
Handling menu to Let Photoshop Determine Colors, select your ABW
profile from the Printer Profile menu, set the rendering intent to
Perceptual. Black Point Compensation won't matter. Might as well leave
it on. Then in the Epson driver, use the exact same settings as you
used to print out the profile target.
The same ABW profile can be used for soft-proofing as well as printing.
Eric
