3MK Disappointment
2007-09-04 by Eric Miner
Hello All, I've been trying very hard to get good results from the 3MK inkset on my R800. The problem is that the ink dropletts are far larger than the R800 gives using other inksets via QTR on the same paper. I've sought advice here and at the QTR group. Paul suggested that I use the paper and profile he did in developing 3MK as a starting point.... still I got very grainy prints due to larger than expected dropletts. I got another suggestion to reduce the ink limit undtil the printer started to print using smaller droplettes...same result, grainy prints due to larger than expect droplettes. At this point I'm tempted to return the unused inkset I bought and go back to Piezo K6 on my R220 where I get prints that are vastly 'smoother' than the R800 using 3MK. Has anybody else seen this issue with 3MK? If so have you been able to 'fix' it? If not tell me about how your R800 is set up and how you're printing. I really want to use the inkset and am willing to try anything to get the fine droplette size that the R800 is capable of. I suspect this is an issue with QTR. I've asked if there is any way to specify droplette size in a profile, but have not gotten a response. Thanks in advance, Eric
