1280/2400
2007-09-14 by rebphoto
Hi Gang............ I posted this on the Epson Printers List and didn't get much in replies............ OK Here is where I am at........ I am currently using two Epson 1280's one for color using InkGrabbers color ink which for an non oem ink has been working fine for me for quite some time and one using MIS UT-2 Black and White Inks. The problem is that on occasion BOTH printers are not recognizing the cartridges but more importantly, since I don't print B&W every day and some times not even once a week the printer using the UT-2 inks will require a lot of cleaning cycles to get it to where it will print where it is not spitting small drops of black ink and also stop banding. It gets rather expensive feeding 11x17 paper into it thinking that this time the printer will finally be clean and will print ok. Epson is offering the 2400 refurbished at a nice price. I was thinking that if I was using just one printer for both my color and my B&W I would not have the problem of having to go through a lot of cleaning cycles to get the printer to print B&W when I needed it to. Does this rezoning make any sense? Also I would be only buying ink for one printer. I see that Ink Grabber offers ink for the 2400 but also Atlex has Epson Ink at a reasonable price. I am going to assume that I print from Photo Shop CS2 and use the 2400 with out any other RIP's etc etc I am not wanting spend my life calibrating a printing system. I don't print "Fine Art" but I do need good prints for my customers. I would appreciate any input on this idea. By the way... I normally print on Ilford Classic & Ilford Smooth Pearl Paper. Thanks Russ R.E. Baker Photography rebphoto@... Feed a Cat... Starve a Fever........ [Non-text portions of this message have been removed]
