Re: [Digital BW] Digest Number 5238
2007-09-22 by James Parker
Ethernet cards in the printers will likely be more workable than Firewire. Trying to network a firewire connected printer may be causing your issue. Try an Ethernet card in one of your printers. Airport is quite slow as a networking device, too, so passing files to the print server is limited to 11Mbs -- you might want to equip your workstations with ethernet cards too. On 9/22/07 7:12 AM, "DigitalBlackandWhiteThePrint@yahoogroups.com" <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
> We have several large format Epson inkjets that are networked. All wkstns > connect via Airport. Managing print queues has been almost nightmarish. > Hence I have been testing a printer front-end, a legacy G4, to which I > would connect via firewire one or more printers (a 4000, 7600, & 9600). I > have tried doing this thru printer sharing, but in tests so far I encounter > 'PrintJobMgr Status 85' & '...Signal6' errors when I access > http://localhost:631. > > Updated to 10.4.10. Reinstalled CUPS 1.2.12. How can I fix this?
