Displaying multiple curves in PS
2007-09-23 by Stephen Kobrin
I cannot fingure out how to display mulitple saved curves at one time
in  Photoshop.  I have several of curves that I use to adjust contrast
before printing and would like to be able to compare them on screen at
the same time to get a visual sense of the differences among them.  At
this point, I plot them on graph paper which seems silly.
Any ideas?
Steve
Re: Displaying multiple curves in PS
2007-09-24 by Clayton Jones
Hello Steve,
>Any ideas?
I'm not a great Photoshop expert but I don't think this is possible.
Clayton
RE: [Digital BW] Re: Displaying multiple curves in PS
2007-09-24 by LeeNWA
Have you tried using duplicate images with each curve applied to see the
difference?
   _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Clayton
Jones
Sent: Sunday, September 23, 2007 9:24 PM
Subject: [Digital BW] Re: Displaying multiple curves in PS
Hello Steve,
>Any ideas?
Clayton
HYPERLINK
"http://www.cjcom.net/digiprnarts.htm"http://www.cjcom.-net/digiprnarts.-htm
Checked by AVG Free Edition.
Version: 7.5.488 / Virus Database: 269.13.28/1023 - Release Date: 9/22/2007
1:27 PM
1:27 PM
2007-09-24 by Stephen Kobrin
I have.  The problem is that you cannot select the duplicate while a
curve is open for the original and visa-versa.  Screen shots may be
the answer here.
Thanks.
Steve
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "LeeNWA"
> difference?
>    _____
Clayton
> Jones
> To: DigitalBlackandWhiteThePrint@...m
> Hello Steve,
> >Any ideas?
> Regards,
> Clayton
> HYPERLINK
9/22/2007
> 1:27 PM
9/22/2007
> 1:27 PM
2007-09-24 by Chuck Behrman
Try using Curves Adjustment Layers (Layer > New Adjustment Layer > curves).
You can have as many as you want or need and independently turn each on on or off.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Stephen Kobrin" <kobrins@...>
> Any ideas?
> Steve
Re:Displaying multiple curves in PS
2007-09-24 by rollin fraser
Steve,
  What you might consider is, with your image open,
make as many new curves layers as you need and then
load your saved curves. By turning each one on and off
you can see the difference each one makes. You could
also duplicate your image and load a different curve
into each one. Hope this helps!
Rollin
2007-09-24 by jnhugo
contrast
at
At
> Any ideas?
> Steve
As I read this post it appears that you just want to see each curve
and be able to look at each one to see how the slopes compare. If
that's right, you can screen capture each one as it is opened And then
make a new file with each image of the curve on a single sheet.  I
used a little free untility called Screenhunter to capture the curve
dialogs
>I would like to attach a sample image to show you but I don't see
that option?
Jack
Thanks to all who have  chipped in here.  I do want to compare the
slopes and it sounds like screen capture is the way to go.  I use a
utility called Easyscreen that works well.
Steve
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "jnhugo"
> contrast
> at
> At
> > Any ideas?
> > Steve
> dialogs
> that option?
> Jack
RE: [Digital BW] Displaying multiple curves in PS
2007-09-25 by Eric Neilsen
Steve, This is a simple feat with an action set that you can write for
yourself.  Some of the other suggestions get you close, but this sounds like
something that you'd like to do more than once or twice.  Make an action
that creates a new layer mask with curves that you use. The action could
even include make a copy from the current state. There could be a save
command if you need to go that far.
You can go back to the image after the action has run and turn on and off
the layers to see. Alternatively within the action make a snap shot of the
image and then you'd only need to click between those version to see your
image. If you like what you see you could save a copy from that state and
print.
Eric
Eric Neilsen Photography
4101 Commerce Street
Suite 9
Dallas, TX 75226
http://e.neilsen.home.att.net
Skype ejprinter
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Stephen
Kobrin
Sent: Sunday, September 23, 2007 4:27 PM
Subject: [Digital BW] Displaying multiple curves in PS
Any ideas?
Steve
2007-09-25 by michaelrosensf
For each curve, display the curve in Photoshop and use a screen grabber (Grab in OS 10.4)
to capture the curve and then save it as a tiff. After you've saved all you want to compare,
open them all and put each in a different place on your monitor. In OS 10 a tiff will open in
Preview when double clicked..
Hope that helps.
Michael
> Any ideas?
> Steve
Re: [Digital BW] Displaying multiple curves in PS
2007-09-25 by Stephen Kobrin
Thanks Eric,
Steve--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Eric
sounds like
and off
of the
your
state and
> print.
> Eric
> Suite 9
> Dallas, TX 75226
