Black rendition with old quadtone set on 3000/QTR
2007-09-24 by Gary Weaver
Hi all,
I plod along with a used 3000. The blacks never seemed as black as the
same black ink in a 1270 doing BO.
Yesterday, the grays were clogged and I got just the black printed.
The after cleaning cycle print does show that the black(RGB 0) is
compromised by the 75pct( I think).
I was using 11x16 thin watercolor pad with one of the glossy settings.
But, the black rendition is the same on other paper. I set-up qtr with
the Inkpress heavy matte.
Am I getting a overprint on RGB 0 because of choosing the wrong paper
type?? I was looking for less ink laydown.
I'm generally very happy with the prints, but in comparing these two
prints the Pure black is being toned down.
Every so often, some B&W imaging filters give me a file that
posterizes in qtr and just re-saving the TIFF clears it up.
thanks,
gar
PRINTER=Quad3000
CURVE_NAME=3000q4test3curve
GRAPH_CURVE=YES
N_OF_INKS=4
DEFAULT_INK_LIMIT=50
BOOST_K=100
LIMIT_K=
LIMIT_C=
LIMIT_M=
LIMIT_Y=
N_OF_GRAY_PARTS=4
GRAY_INK_1=K
GRAY_VAL_1=100
GRAY_INK_2=C
GRAY_VAL_2=63
GRAY_INK_3=M
GRAY_VAL_3=43
GRAY_INK_4=Y
GRAY_VAL_4=13
GRAY_HIGHLIGHT=10
GRAY_SHADOW=8
GRAY_OVERLAP=10
GRAY_GAMMA=1
GRAY_CURVE=
N_OF_TONER_PARTS=0
TONER_HIGHLIGHT=0
TONER_SHADOW=0
TONER_GAMMA=1
TONER_CURVE=
N_OF_TONER_2_PARTS=0
TONER_2_HIGHLIGHT=0
TONER_2_SHADOW=0
TONER_2_GAMMA=1
TONER_2_CURVE=
N_OF_UNUSED=0
LINEARIZE="100 98 96 93 91 88 85 81 76 69 62 56 49 43 36 29 22 16 13 7 3 "
Re: Black rendition with old quadtone set on 3000/QTR
2007-09-25 by dlruckus
Hi Gary.
Try zeroing out the gray overlap. You have 10% of the gray as going
into the full black. That could do what you are seeing. You also have
100% boost set up so you might be flooding the paper a bit as well.
Duane
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Gary Weaver"
<garww@...> wrote:
> Hi all,
> thanks,
> gar
> PRINTER=Quad3000
> GRAPH_CURVE=YES
> N_OF_INKS=4
> BOOST_K=100
> LIMIT_K=
> LIMIT_C=
> LIMIT_M=
> LIMIT_Y=
> N_OF_GRAY_PARTS=4
> GRAY_INK_1=K
> GRAY_VAL_1=100
> GRAY_INK_2=C
> GRAY_VAL_2=63
> GRAY_INK_3=M
> GRAY_VAL_3=43
> GRAY_INK_4=Y
> GRAY_VAL_4=13
> GRAY_HIGHLIGHT=10
> GRAY_SHADOW=8
> GRAY_OVERLAP=10
> GRAY_GAMMA=1
> GRAY_CURVE=
> N_OF_TONER_PARTS=0
> TONER_HIGHLIGHT=0
> TONER_SHADOW=0
> TONER_GAMMA=1
> TONER_CURVE=
> TONER_2_HIGHLIGHT=0
> TONER_2_SHADOW=0
> TONER_2_GAMMA=1
> TONER_2_CURVE=
> N_OF_UNUSED=0
7 3 "
2007-09-25 by Gary Weaver
Duane!!
Thanks for the input. I have to measure color values with a scanner
and I was getting 3-4 points difference between the two renditions.
What you say here makes sense. I couldn't equate the gray overlap as a
percent, so thanks.
gar
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "dlruckus"
<dlruckus@...> wrote:
> Hi Gary.
> Regards
> Duane
> <garww@> wrote:
> > Hi all,
> > thanks,
> > gar
> > PRINTER=Quad3000
> > GRAPH_CURVE=YES
> > N_OF_INKS=4
> > BOOST_K=100
> > LIMIT_K=
> > LIMIT_C=
> > LIMIT_M=
> > LIMIT_Y=
> > N_OF_GRAY_PARTS=4
> > GRAY_INK_1=K
> > GRAY_VAL_1=100
> > GRAY_INK_2=C
> > GRAY_VAL_2=63
> > GRAY_INK_3=M
> > GRAY_VAL_3=43
> > GRAY_INK_4=Y
> > GRAY_VAL_4=13
> > GRAY_HIGHLIGHT=10
> > GRAY_SHADOW=8
> > GRAY_OVERLAP=10
> > GRAY_GAMMA=1
> > GRAY_CURVE=
> > N_OF_TONER_PARTS=0
> > TONER_HIGHLIGHT=0
> > TONER_SHADOW=0
> > TONER_GAMMA=1
> > TONER_CURVE=
> > TONER_2_HIGHLIGHT=0
> > TONER_2_SHADOW=0
> > TONER_2_GAMMA=1
> > TONER_2_CURVE=
> > N_OF_UNUSED=0
> 7 3 "
