Re: [Digital BW] Problem with monitor - print matching
2007-09-26 by CDTobie@aol.com
In a message dated 9/26/07 4:24:33 PM, r.smallfield@... writes:
> I print about half colour and half black and white.
> In both cases, despite different work flows, the prints are darker and
> contrastier than the monitor.
> My monitor is calibrated and for colour I use custom profiles, so they
> should match.
> My BW printing is done with QTR but, as I can't afford a spectro, I use the
> standard profiles and curves.
> I do get good results in the end, but only after too much proofing.
> What link in the chain is likely to be the problem? My monitor is a Philips
> CRT ... must be about 3 years old.
Ambient light levels, and especially proofing light levels, are the usual
culpret. Sounds obvious when worded this way but: if you shine a brighter light
on your print, it will show more detail and less contrast as the shadows and
midtones are more open under brighter lighting. This is more common with LCDs,
where users run a very dim studio, and an old proofing light, but a newer,
brighter LCD.
An old, dull CRT with low luminance will show minimal contrast, but usually
looks darker, not lighter, than the print. So there are a number of
possibilities, most of which center around monitor luminance, proofing luminance, and
ambient luminance...
C. David Tobie
Product Technology Manager
ColorVision Business Division
DataColor Inc.
CDTobie@...
www.colorvision.com
 See what's new at
http://www.aol.com
2007-09-26 by Richard Smallfield
Thanks a lot ... I usually look at proofs under a full-spectrum fluorescent light.
But I have been leaving the big window at the back of the room unblinded lately. Stupid me.
What's the average age limit for a CRT monitor?
thanks,
Richard
>brighter LCD.
http://smallfield.vze.com
http://photos.smallfield.vze.com (Photos web site)
http://warkworth.vze.com/ (Warkworth photo essay)
http://picasaweb.google.com/rsmallfield/ (Recent work)
   "A liberal is a person whose interests aren't at stake,
   at the moment."
   --Willis Player
2007-09-27 by deandadin@aol.com
Hello Richard, I had the same problem with my printing recently.   If your
prints are consistantly too dark or too light, All you have to do is change the
brightness and contrast of your monitor.   This one thing completely changed
the way I print. Sometimes I still get a print that has to be worked on but for
the most part the darkness or lightness is greatly improved.   Generally if
your prints are coming out too dark, darken the monitor.   If your prints are
coming out too light lighten the monitor.   Also if your prints are too
contrasty increase   your monitor contrast and etc. You have to do the reverse of the
problem you are having. I hope that this helps you. Steve
 See what's new at http://www.aol.com
2007-09-27 by CDTobie@aol.com
In a message dated 9/26/07 8:09:02 PM, deandadin@... writes:
> the
Well, changing it manually, after the monitor is calibrated and profiled
isn't ideal, nor is it measured or repeatable. The idea is to determine the
correct monitor white luminance (contrast control) and black luminance (brightness
control) as part of your calibration process. This allow multiple monitors to
be matched, and relates all of them to the ambient/proofing light. Just messing
with the controls is the cowboy approach.
C. David Tobie
ColorVision Business Unit
Datacolor Inc.
CDTobie@colorvision.com
www.colorvision.com
 See what's new at
http://www.aol.com
