Thanks for help on Aust Epson R230
2007-09-27 by Ronald K. Johnson
Thanks for the help, read the archives and seems like the R230 similar to R220. The R230 is being replaced in oz with R250 so I took a punt and got me the R230. I have a available a chip resetter for the R230 so as soon as I have set-up and played with the printer will be looking for MIS inks. Will need advice as best set-up for BW printing from CS2 using existing inks (6 tanks). Thanks again from down under. Ronald K. Johnson
2007-09-27 by John
The R250 is totally different, it's using 4 ink cart. unlike R200, R210, R220 and R230 printers are using 6 individual colour ink cartridges: http://www.epson.com.au/products/inkjet/stylusPhotoR250.asp Best set-up for your R230(same as R220)and CS2 using MIS inks is with Paul Roark's workflow: 1. R220 - R2 http://www.paulroark.com/BW%2DInfo/R220_R2_Readme.pdf http://www.inksupply.com/utr2.cfm 2. R220 - UT-3D http://www.paulroark.com/BW%2DInfo/UT-3D_Readme.pdf http://www.inksupply.com/ut_3d.cfm Hope this helps John --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Ronald K. Johnson" <vk5akj@...> wrote: > > Thanks for the help, read the archives and seems like the R230 similar > to R220. The R230 is being replaced in oz with R250 so I took a punt > and got me the R230. > I have a available a chip resetter for the R230 so as soon as I have > set-up and played with the printer will be looking for MIS inks. > Will need advice as best set-up for BW printing from CS2 using existing
> inks (6 tanks). > Thanks again from down under. > Ronald K. Johnson >
2007-09-28 by Ronald K. Johnson
Yes John, seems my dealer got it wrong, wonder what the replacment for the R230 will be ?. Anyway doesnt matter as I have the R230. Thanks for the help. ron --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "John" <firewoodtech@...> wrote: > > The R250 is totally different, it's using 4 ink cart. unlike R200, > R210, R220 and R230 printers are using 6 individual colour ink > cartridges: > > http://www.epson.com.au/products/inkjet/stylusPhotoR250.asp > > Best set-up for your R230(same as R220)and CS2 using MIS inks is with > Paul Roark's workflow: > > 1. R220 - R2 > http://www.paulroark.com/BW%2DInfo/R220_R2_Readme.pdf > http://www.inksupply.com/utr2.cfm > > 2. R220 - UT-3D > http://www.paulroark.com/BW%2DInfo/UT-3D_Readme.pdf > http://www.inksupply.com/ut_3d.cfm > > Hope this helps > > John > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Ronald K. > Johnson" <vk5akj@> wrote: > > > > Thanks for the help, read the archives and seems like the R230 > similar > > to R220. The R230 is being replaced in oz with R250 so I took a punt > > and got me the R230. > > I have a available a chip resetter for the R230 so as soon as I have
> > set-up and played with the printer will be looking for MIS inks. > > Will need advice as best set-up for BW printing from CS2 using > existing > > inks (6 tanks). > > Thanks again from down under. > > Ronald K. Johnson > > >
