Effect of aluminum-based coatings (e.g. Harman) on permanence?
2007-10-06 by t_j_l_s
Most aluminum compounds are rather chemically active.  Does anyone have an opinion on
what to expect in terms of print permanence from papers like the reportedly wonderful
looking new Harman that uses an "Alumina" coating to control ink absorbtion?
Thor
Re: [Digital BW] Effect of aluminum-based coatings (e.g. Harman) on permanence?
2007-10-06 by Robert Damon
"Alumina" is aluminum oxide (Al2O3). Here is a link with some
information: http://en.wikipedia.org/wiki/Aluminium_oxide
It's pretty stable stuff. I've used it as a chromatography stationary
phase. In this technique, one passes solutions of mixtures of organic
compounds though a column packed with the stuff. The solutes are
differentially absorbed which allows their separation as the solvent
passes through the column. A wide variety of organic solvents can be
used. Among other things, this indicates its general inertness to
organic solvents. It normally doesn't cause problems for the solvents
or solutes used in this process either.
Here's a reference to that process in the event that you're curious:
http://en.wikipedia.org/wiki/Column_chromatography
Whether the stability of the alumina translates into stability of an
image printed on this paper is another matter, about which I have no
direct knowledge. However, I've tried the Harman Gloss FB Al paper
(Epson 3800) and I like it.
> have an opinion on
> absorbtion?
> Thor
2007-10-07 by Ernst Dinkla
> Thor
There's no independent fade testing of any of the Baryta
(barite) papers including the ones with Alumina top layer so
it will be difficult to get that information.
Henry Wilhelm says something about Barium Sulfate versus
Titanium DiOxide and analogue RC papers but it goes a bit
further than just RC papers. Interesting comments about
Barium Sulfate and the use of OBAs in the second one.
http://www.wilhelm-research.com/phototechniques/PhotoTechniques_WIR_2005_01.pdf
http://www.wilhelm-research.com/pdf/HW_Book_17_of_20_HiRes_v1a.pdf
on Alumina: you can get a paper with two articles on Alumina
http://www.imaging.org/store/epub.cfm?abstrid=34162
http://www.imaging.org/store/physpub.cfm?seriesid=5&pubid=670
Degussa AG most likely is the supplier of what we see used
right now, they have more varities
http://www.patentstorm.us/patents/6808769-description.html
You could make your own coating and tests based on that
article :-)
The Alumina (or actually the manufacturing process) is in
the first place created to give a gloss surface by its
uniform, small particle size. I'm sure they will have tested
the other aspects like fade properties as well. The PVA
mentioned as the binder for the Alumina has good properties
and is used in inkjet inks as well.
Aluminium pure is chemically active as it easily oxidises in
a variety of environments. But quite inert in its oxidised
form. What could be interesting to the use with inkjet inks
is the anodising-eloxal process to give aluminium a nicer
more durable finish with or without color. In that case
several dye types are also used, see dyes at the bottom of
this webpage article.
http://en.wikipedia.org/wiki/Anodising
The layer is afterwards sealed by further expansion of the
top surface, encapsulating the dye component.
Met vriendelijke groeten,  Ernst
|  Dinkla Grafische Techniek  |
|     www.pigment-print.com    |
|             ( unvollendet )            |
TiO2, Baryta and optical brighteners .. was Effect of aluminum-based coatings (e.g. Harman) on permanence?
2007-10-09 by Ernst Dinkla
Following up on the comment above.
In the euphoria about Baryta papers it would be good to
check one thing thoroughly: to get a whiteness equal to the
TiO2 coating whitener as used in RC polyethylene and nonRC
paper coatings a thicker Baryta coating is needed and I
suspect more optical brightener. The Barium Sulfate
refractive index is way lower than that of TiO2. The link
above describes the advantage of barium sulfate not blocking
UV light and by that giving the optical brighteners their
best effect. The optical brightener can be added to the
paper base instead or additional to the coating for the same
reason. There are reservations about the use of optical
brighteners and alternative whiteners. UV stability of both
are not at the level of TiO2. That alternatives for TiO2 are
sought is not just for nostalgic (darkroom) reasons, TiO2 is
more expensive so blends with other (cheaper) whiteners are
made and other whiteners are developed to give them TiO2
specs, primarily by getting the particle size and uniformity
close to that of TiO2. The new Alumina mentioned is one
example but Alumina itself in clay coatings isn't new. What
Baryta content actually is used in the paper coatings is a
mystery. The Sihl Baryta specs mention a high Barium Sulfate
content but not that it is the sole whitener in the coating.
There is little or no optical brightener in that paper and
both base and coating color are warm. It is hard to check
how good development has been on substitutes for TiO2 not
just in their opacity and whiteness but also in relation to
stability in time. One thing is sure, the Baryta coating on
inkjet papers of today isn't an exact copy of the analogue
Baryta coating of >10 years ago.
This was written in 1999 (hard to read in Firefox, Explorer
is good):
http://www.allbusiness.com/manufacturing/plastics-rubber-products-manufacturing/294696-1.html
|             ( unvollendet )            |
Re: TiO2, Baryta and optical brighteners .. was Effect of aluminum-based coating
2007-10-09 by djon43
Ernst, I'm under the impression that alpha-cellulose and bamboo papers
are free, or relatively free from whiteners...
...because the fibers themselves are inherently bleached thoroughly,
unlike more whitened papers, including the new conventional papers
that are Baryta-coated.
Is there anything to that?
Why are (some) alpha-cellulose papers so much more white than most
whitened cotton papers? ...Thinking here of Inkjetart's micro-ceramic
and Legion's LaSal (and the old Moab's Kayenta).
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Ernst Dinkla
> is good):
> |             ( unvollendet )            |
2007-10-09 by john dean
I know. It is all a science experiement and we are the lab animals.
Breathing Color has the bright white rag paper and canvas out there
now that they promote as having no obs's at all. They do give the
illusion of better gamut and dynamic range, and make Photorag for
instance look off white. It becomes a situation of terminology. What
is an oba, and does another whitener ( almost all papers have some
kind of whitener) have any added stability benefits, or could they be
worse.
john
 It is hard to check
> is good):
> |             ( unvollendet )            |
