Getting started with my Epson 1280
2007-10-14 by Paul Whiting
Hello,
I started a thread a few days ago, asking if I could use QImage with
my recently purchased Epson 1280 and its accompanying Piezography
BWICC inks. Paid $100 for the works, seemed like a good deal. Got
several good comments, thanks to all of you.
But it turns out the carts are dated as expiring in June 06... will
this be a problem?
Also, I fired up the printer for the first time yesterday, it has
installed in it a set of non-OEM carts, both black and color. They
register as 3/4 full but I get absolutely no printout with them, in
either the nozzle check test or a six color test TIFF print. The
printer is practically new, shows no signs of stray ink anyway, very
clean all around. But that's the problem, it hasn't been used for
months, perhaps even a year, and the heads may be clogged. A friend
thinks otherwise, thinks the heads may be ok, and that even if the
carts show 3/4 full, that the ink has gelled.
What's my plan of attack here? Should I first try and unclog the
heads, get some inexpensive color carts from MIS to see if I can at
least get a print of some kind? Should I try the MIS cleaning carts?
Also, am thinking I'm not wedded to these Piezography carts,
especially if they're expired. May want to go the MIS route, one
reason being I can refill those and my expenses will be less in the
long run.
As always, I appreciate the helpful people here!
Re: Getting started with my Epson 1280
PS Please tell me if this question is more appropriate over in the
Epson printer group. However, my question is partly a BW printing
issue, ie Piezography vs MIS, so I guess that part of my question is
appropriate here.
Re: [Digital BW] Getting started with my Epson 1280
2007-10-14 by CorrPro96@aol.com
In a message dated 10/14/2007 3:56:51 P.M. Eastern Daylight Time,
paulmwhiting@... writes:
long run.
Can you get your $100.00 Back?
Richard Massie
************************************** See what's new at http://www.aol.com
Re: [Digital BW] Re: Getting started with my Epson 1280
In a message dated 10/14/2007 4:04:20 P.M. Eastern Daylight Time,
appropriate  here.
If you can't get your $100.00 back.... take $90.00
Richard M
2007-10-14 by djon43
Yes, do try the Epson printer group, as well as Digital Darkroom at
Photo.net
I've seen some superb 1280 work in B&W print exchanges with MIS, and
there's no reason to think Piezo wouldn't be as good. IMO in B&W the
1280 rivals 2400 if you can accept Black Only characteristics (dots).
The Epson driver's perfect for Black Only.
If your plan involved color I'd say forget it unless you're after
hypersaturated flash with very reduced longevity.
Unclogging would seem the only real challenge if B&W's your goal.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Whiting"
> appropriate here.
2007-10-15 by Tyler Boley
hard to say for sure, but the easiest thing is to take that advice and go another route.
However, you could get a cleaning cartridge, let it sit for days with a couple of cleaning cycles
a day, and let the head sit on a windex soaked paper towel, etc.. Maybe even forcing windex
through the nozzles with a syringe and tubing.
Could work, who knows?
Tyler
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Whiting" <paulmwhiting@...>
wrote:
> I might be able to... the situation's that bleak, eh? Ah, well!
> > Richard Massie
2007-10-15 by CorrPro96@aol.com
In a message dated 10/14/2007 10:44:18 P.M. Eastern Daylight Time,
tyler@... writes:
another  route.
forcing windex
Tyler
<paulmwhiting@...>
> > Richard  Massie
I ran 2 1280's with Piezo CIS, and got really nice prints from them. One  was
warm, the other selenium. There seems to be a time limit though, before the
clogging and ink starvation thing catches up to you. I think the problem is
usage. At first, you have a bunch of stuff to print and everything goes well.
It's when the bunch of stuff is no longer there, and it's just a print now and
 again, that things start to muck up on you. You have to remember that the
1280  is a dye ink printer with a piezo head. If you get one that's running
well,  that's one thing.... but the printer in question has had it. The party is
over  and the band has packed up.
Even if you only get 90 bucks back, you'll save a couple hundred and the
rest of ya hair.
Richard M
2007-10-15 by Antonis
> this be a problem?
Paul,
I wouldn't worry about that expiration date. One year past isn't too
critical. I would, however, give the carts a gentle shake or two
before installing. Even the best of pigments can settle with time.
> heads,
I'd say yes. Read up on unclogging the 1280 (used to be lots of info
on the web). Take Tyler's advice. Be patient with the cleaning cycles.
Don't do too many in a row....
The MIS cleaning carts (or any carts you can fill with some water and
windex or similar, preferably warm) should be what should sit in the
heads while you are trying to unclog them.
I'd skip the color carts and go straight to the Piezo carts after the
cleaning process. Worse that can happen is you'll go through them
while trying to get the heads to work. If at the end the printer is
good to go, you buy whatever ink you choose to print with and you'll
be starting with a fresh set.
> long run.
The expiration is a minor issue compared to the difference between
these two inksets (piezo vs MIS), their properties and the drivers and
profiles needed to run them. Depending on your level of experience and
technical confidence go with what you feel more secure about.
If indeed you have a constant volume of printing such that refilling
carts will be worth the hassle, consider a Continuous Flow System. But
then, never let the printer sit idle for longer than a week...
Antonis
