Red River Ultra-Pro Satin 2.0 3 month fade report
2007-10-26 by Steven Karafyllakis
I put 4 grayscales out in my south window on 7/17. They are receiving
10-12 hrs of ambient light a day, with 3-4 hrs in the afternoon being
direct (but not over-head) sunlight. The window is 1/4 inch standard
glass.
Two scales are coated with PremierArt, two are not. Of each pair one
is MIS K4 printed in my R1800, the other Epson K3/SP3800. Each scale
has a black mattboard strip covering the middle 1/2-inch.  Readings
taken with a Colorvision spectrophotometer.
MIS coated: Start, 2.4   @ 3 months, 2.35    Epson coated:  Start,
2.59  @ 3 months, 2.53
MIS uncoated: Start,  2.31  @ 3 months  2.25  Epson Uncoated: start,
2.48  @ 3 months 2.41
Lifting the strip of black cardboard, I can't yet see a divider line
between the covered and uncovered parts on any of the scales.
The 'b' value of the base started at -3.4, initially went a bit bluer
(OBAs burning off?) now is drifting back towards yellow a bit, but
none of the blueness shifts are visible. This continues to be a
warmer than average base color for an RC paper, but with  no rapid
yellowing visible, unlike SOME of the RC papers I've tested.
I like this paper, it prints with good presence and tonal separation,
and the warmer base makes it easier to mat.
Steven Karafyllakis
Re: [Digital BW] Red River Ultra-Pro Satin 2.0 3 month fade report
2007-10-26 by Harry Lockwood
Steven,
Ordinary window glass is a pretty good absorber of UV.  Standard window
glaze is about 2mm, a bit more than 1/16 inch.  If your windows are 1/4 inch
thick, they are not ³standard.²  Since absorption is exponential with
thickness, a factor of 4 in thickness will be very significant.
Harry
On 10/25/07 11:29 PM, "Steven Karafyllakis" <stevekphoto@...>
> glass.
> Steven Karafyllakis
Harry F. Lockwood
Make of it what you will, Harry. Other papers have faded visibly and
yellowed in less time under the same conditions. For me, this paper
is above average FOR AN RC PAPER in both printing ability and fade
resistance. As they say, Your Mileage May Vary.
Steve
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Harry Lockwood
<hflockwood@...> wrote:
> Steven,
window
1/4 inch
with
> Harry
receiving
being
standard
> > glass.
one
scale
Readings
start,
line
bluer
separation,
> > Steven Karafyllakis
> Harry F. Lockwood
Re: Red River Ultra-Pro Satin 2.0 3 month fade report
2007-10-27 by Manuel Toledo
With MIS K4, I like RR Polar Satin. A bit warmer than ultrapro.
RR publishes the results of their own fade tests in this page:
http://www.redrivercatalog.com/infocenter/printlife_nav.htm
They report 35 yrs. for polar and 47 years for ultrapro.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven
> glass.
> Steven Karafyllakis
