QTR versus PrintFixPro with UT3D
2007-11-23 by Joost Horsten
Hi all,
Currently I'm using UT3D inks in combination QTR (on an Epson 2100).
I work on PC and I make my profiles with an Eye-one. I'm very happy
with this setup in terms of print quality and toning versatility. But
since I made Lightroom the centerpiece of my workflow (still doing
the major editing work in PS), I get more and more annoyed by the
fact I can't print directly from Lightroom. I know there are several
workarounds (e.g. saving as pdf and then converting to tiff etc.),
but it's just not convenient.
So for some time I'm considering to sell my Eye One and purchase
PrintFixPro. Since UT3D is essentially a full spectrum, though low
saturation, inkset that should allow for color managed work flow with
all conveniences of it: printing directly from Lightroom, previewing
toning, spatially different toning. This has been advocated on many
occaisions here.
But from a private e-mail conversation with one of the group members
I learned that the UT3D+PFP approach is nice in theory, but that in
practice it is dissappointing since one loses almost all toning
potential of UT3D and that prints are always essentially neutral.
Apparently the color mapping done in PFP clips a large chunk of the
UT3D gammut. After hearing this, I do recall an earlier remark in
this group (I think it came from Paul Roark), that indicated
something likes this, but not as severe as I learned recently.
Any experiences or insights in this? Is this is true indeed, than PFP
will be no good for me and I'd rather stick with my workarounds.
Joost
Re: QTR versus PrintFixPro with UT3D
2007-11-30 by Joost Horsten
I take the liberty to bump this one. No opinions this whatsoever? C.
David Tobie, I'd expect you will have some first-hand insight in this.
Joost
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Joost Horsten"
<j.h.j.h@...> wrote:
> Hi all,
2100).
But
several
with
previewing
> occaisions here.
members
PFP
> Joost
Re: [Digital BW] Re: QTR versus PrintFixPro with UT3D
2007-11-30 by CDTobie@aol.com
In a message dated 11/30/07 6:17:54 AM, j.h.j.h@... writes:
I've answered this one recently, but apparently not here. This has to to with
specialty B&W inksets, which are typically used with a specialty B&W RIP,
most commonly QTR. The typical workflow would be to build custom curves for QTR
using PrintFIX PRO or Spyder3Print to take the measurements and export them to
QTR or its CreateICC Utility.
The other option is to build an RGB driver profile totally inside PFP or
S3Print. That works for me, in what testing I've done, to produce a neutral
profile, if the combination actually can reach neutral. But the complexity comes in
with how to tune such a profile for non-neutral printing. Since the gamut is
tiny, the adjustments the the PFP/S3Print sliders can make are similarly tiny.
I suspect the best solution, if one choses this rather unusual route, is to
have the neutral image in RGB in Photoshop, and to use the neutral profile to
softproof, then to carefully adjust the RGB curves to tint the image. Once you
get a print with the tonality you want (if you can, so to speak, get there from
here) that RGB curve set can be imported into PFP/S3Print to make it part of
the profile.
All of this is pretty far of the radar in terms of typical PFP/S3Print usage.
Personally I'd recommend getting a "two grays" printer, leaving the standard
inkset in it, and printing color as well as B&W from it, using our profiles
for both, with your choice of printing via the color mode for B&W and tinted B&
W, or the driver's B&W mode, with one of our profiles in either case, though
the tint is controlled by the driver settings, if you use the driver B&W mode,
and PFP/S3Print is only used for density control and softproof capablities.
C. David Tobie
Product Technology Manager
Digital Imaging & Home Theater
Datacolor
CDTobie@...
www.datacolor.com/Spyder3
Check out
AOL's list of 2007's hottest products.
(http://money.aol.com/special/hot-products-2007?NCID=aoltop00030000000001)
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, CDTobie@...
wrote:
Hi David,
Thanks for your comprehensive answer.
> This has to to with
B&W RIP,
curves for QTR
export them to
Which is what I currently do.
PFP or
a neutral
complexity comes in
the gamut is
similarly tiny.
route,
As a matter of fact, I recall it was yourself who advocated the
combination of UT3D and PFP roughly a year ago...
> is to
profile to
image. Once you
get there from
it part of
> the profile.
PFP/S3Print usage.
the standard
profiles
and tinted B&
case, though
driver B&W mode,
capablities.
... but I accept that further insight can lead to a different
conclusion now.
Thanks for the explanation. The conclusion is clear: as long as I
stay with UT3D, or another B&W inkset, I can happily stay with my
Eye-One.
Joost
In a message dated 11/30/07 2:33:17 PM, j.h.j.h@... writes:
> Eye-One.
Yes, there are some places where Spyder3Print offers advantages over other
available options, but for working with third party grayscale inksets, one
patchreader or the other will get you pretty much the same result.
C. David Tobie
Datacolor
CDTobie@...
Check out AOL's list of 2007's hottest
products.
