Ebony Ink
Ebony Ink
2007-12-03 by photoguy102002
Hello Have a question
I am using a 2400 with matt black installed, I use MIS K4 inkset with
their Eboni matt black.
I cannot get a neutral print using QTR no matter what curves I use.  I
have tries several papers with the same results.
I can get a netural print by using a profile.
I know that Eboni ink is warm, I though that I could by blending curves
get a neutral print. Is this possible with the combo I am using.
Thanks in advance.
Ed
Re: Ebony Ink
2007-12-03 by Louis Dina
Ed,
Yes, you can get a neutral print using QTR.  There are two
ways....when printing, blend a warm profile with a cool profile,
experimenting until you get the percentages that give you a neutral
print.
Or, you can create a single profile that is neutral for each paper,
which is what I do.  I'm using a 2200 and a 4000, using MISPro color
inks, which only have two shades of black, Eboni and LK.  I don't
have the LLK ink.  To get a neutral profile, you will have to add
some LC and LM in roughly equal proportions to cool off the natural
warmth of your Eboni, LK and LLK inks.  It takes a little
experimentation and trial and error.  Once you have it the way you
like it, you should be able to use the same approximate percentages
on other papers, but you will probably need to set a new default ink
limit and relinearize, depending on the paper.
If you are not building your own profiles, try the blending approach
mentioned first, or look in the files section of this site to see if
someone has posted neutral profiles for the 2400, your inkset and
your paper.
Lou
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "photoguy102002"
with
use.  I
curves
> Thanks in advance.
> Ed
