notches on the L* axis
2007-12-06 by eappert
Hello,
I am confused about how file data of  equal brightness values are
translated to the target profile. I assumed that the file data range
of 255 brightness levels  would have to be translated through the 100
L* distinctions in the proifle connexion space. Yet I can see
brightness distinctions on the screen from RGB 1 to RGB 9 which
should all translate to L*1 . When I first noticed this I thought it
was possible BPC was using the RGB data to remap the brightness
higher,  but I notice the same the thing much farther up the curve.
My monitor regesters a distinction between RGB 72 and RGB 73 ( L* 30)
which is maintained after converting to a target space. For example
in us
swop coated v2   66%, 60% 58% 42% and  66% 59% 58% 41%, which both
translate as L*30.
I have just taken the experiment all the way to the print to remove
any file to monitor anomalies. I printed a chart in a 2.2 RVB space
of all 255 levels contained in blocks of L*. So for example in the L*
1 patch there were inner patches containing RGB values from 1 to 13,
the L*54 patch containing RGB 128 & 129, etc. I printed out the chart
on the widest range output I have (Epson 3800 on Museo silver rag)
using an eye one colour profile.
When the print was coming out of the printer I breathed a sigh of
relief because,  from a distance and under normal light all L*
patches appear uniform. However when I bring the print up very close
under powerful light, some L*patches seem to contain very, very faint
ghostly appearances of the inner patches. Either the data got through
to the control signals of my printer or they are the results of badly
digested bits of beef.
This phenomenon seriously challenges my understanding of colour
management
Any help out of the rabbit hole would be greatly appreciated.
Eugene Appert.
