Eboni-6 inkset - Bases
2007-12-18 by Paul Roark
This is just an update on this approach, and note on warmth and wetting agent. The inkset is looking like it'll be good for most 3 pico liter and larger Epson printers. While the older large format printers were the original target, the 1440 Epson driver + Create-ICC quality and ease are such that this'll work on about anything. The updated PDF is at http://www.paulroark.com/BW-Info/Eboni-6.pdf I think I've made the final base decision, and it's been running well enough for several months now that I think it's ready for production. I have not heard a date from MIS as to when it'll be on the web page. I recommend bulk only sales at first. Obviously, getting a warm print from carbon pigments is easy. Getting one that is neutral enough for me to be happy with the way clouds and snow look has been the problem. Specifically, holding down the maximum Lab B is the trick. There are several papers that do it fine with the final mix. So, it's done as far as I'm concerned. There is a way to lower the Lab B slightly more. The bare bones base I make from 4 parts water to 3 parts glycerol is the coolest printing base. The Eboni-LK made with this hits a maximum Lab B=0.7 on Premier Art Smooth BW, as opposed to the 1.6 for the base that will be used in the MIS version. With the lighter inks the difference is less. As such, an actual inkset for most uses would have such a small difference that it's just not worth messing with. The difference is probably due to the lack of wetting agent. When Photo Flo is added to the glycerol base, the warmth jumps up to the production base numbers. There is a trade off between smoothness and warmth. The model of the warmth coming from the relatively transparent circumference still holds. While I will probably do no more with this, those who want the coolest-printing and cheapest dilute Eboni inkset can mix from this home-made base. It'll probably still be smooth enough in modern printers if multiple jets are firing. I'm less certain a single Eboni-LK made with the stripped down glycerol base would be good enough. I would not use it. At any rate, I think the inkset is in its final form. I'll hope to be testing a Canon with it next week. Paul www.PaulRoark.com <http://www.paulroark.com/> [Non-text portions of this message have been removed]
