Hello AnnMarie,
>I just wanted to share my experience, so far, with the 2400. I
>received it a few hours ago and after playing with settings and
>seeing what works for me, I am very excited and pleased with
>the output.
Congrats on the 2400. I'm sure you'll find it to be a great printer.
>Perhaps I am a bit naive or I am just easily impressed, but the
>range of tones with such smooth transitions with the K3 inks are
>amazing!
Well, I don't think it's your imagination, it really is a fine printer
and has a good reputation for a reason. It has changed many people's
BW printing lives <g>.
>...the settings have to be tweaked with each image. Though
>necessary, it's a pain in the butt.
I found that after a couple of weeks testing with different papers and
images I got it pretty well figured out and settled down into a
regular range of settings. So give it a bit of time. Here are some tips:
1) Try ABW settings around 2,8 and 4,8 for close to neutral tone on
VFA and HPR. Each paper will have it's own setting for your preferred
tone.
2) The challenging part of K3 printing is how any color influence from
the ABW setting shows most easily in the midtones. Depending on how
much midtone areas are in an image, this influence is more or less
visible. So a high contrast image with not as much midtone dominance
will be easier to find agreeable settings. But one with lots of
important middle zones will be more persnickity in finding a tone you
like.
3) Don't assume your ABW settings are carved in stone. There are
minor differences in ink batches, so slight changes may be necessary
after changing carts. For example, after changing an LC or LM cart,
an image that printed at 4,8 may have to be printed at 2,8 or 3,8.
Also, a nearly empty cart may print differently than when it's full.
If I'm reprinting an image I haven't printed in awhile, I first make a
small test print to see if the setting needs to be adjusted.
Have fun!
Clayton
