[Fwd: Re: [Digital BW] Eboni-6 tones, etc.]
2008-01-10 by Roger
I should add that I don't spray or coat my prints at all. Am I about to
get a lecture?
Roger
-------- Original Message --------
Paul, thank you very much. Very helpful.
All,
I am thinking these carbon inks are a solution to a major problem I've
observed with the UltraChrome inks, to wit, even with UV protective
glass, a few minutes in sun causes the ink to outgas a haze which
condenses on the glass. The image changes in a way that resembles
bronzing. This has happened to me at two different shows (Crested Butte
and Teton Village) at relatively high altitude, but I took care to make
sure the sun was only at a glancing angle--didn't seem to help. One
additional piece of info is that both images were color.
Fortunately, the condensed haze evaporated after the framed print was in
  the dark for a couple of days. These images had been printed for two
months before they were framed.
1. Will the glycerin suspension in the Eboni-6 ink cause the same problem?
2. Are there 3rd party ink cartridges or CIS systems for the Epson 7600
that will accomodate the Eboni-6 ink?
3. Is it a plausible idea to buy a used 7600 to dedicate to the Eboni-6 ink?
I've got a 4800 using the standard Epson ink and profiles that I'm quite
pleased with, as long as the images are protected inside and away from
the sun. I like to do some color printing, but the majority of my work
is B&W.
Roger
Palmer Lake, CO
www.mindseyephoto.com
pr_roark wrote:
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com
> <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com>, Roger
> <user1@...> wrote:
>  > Paul,
>  > I'm new to this users list, so here's a couple questions:
>  > 1. What is BO printing?
> "Black ink only" printing; ...
>  > 2. On your chart, is the Y axis something like a difference from
>  > expected value in db, or some other unit?
> The Y axis shows the Lab A and B units. Positive Lab A values
> indicate red (more of a magenta-red to me), and negative Lab A values
> indicate green. Positive Lab B values are yellow, negative blue.
whoa! I was way off in the concept!
> Paul
> www.PaulRoark.com
