Calibrating scanner with Vuescan
2008-01-11 by Edson Françozo
Hi!
I intend to calibrate my HP G4050 in order to make ICCs for some
watercolor papers I have. I am following Paul Roark�s directions
(http://paulroark.com/BW-Info/Making_B-W_ICCs.htm). In this article,
Paul advises to use highlight, shadow and gamma controls for
calibration. Vuescan, however, does employ this terminology. My
question, for those familiar with Vuescan, is: am I right in assuming
that, in the Color tab, black point and white point controls correspond
to shadow and highligth, and that brightness correspond to gamma?
Edson
Re:Calibrating scanner with Vuescan
2008-01-11 by kolwicz@minetfiber.com
It looks like you are quite right.
http://www.hamrick.com/vuescan/html/vuesc26.htm#topic25
has the following quotes regarding
Brightness, White Point and Black Point:
     "Brightness
     Use this option to increase or decrease
the overall image brightness.
     VueScan's brightness is effectively a
multiplier of the gamma of the color space."
  "White point (%)
     The white point is used by the color
balance algorithm and is computed by using
the histogram of each color in the image. Use
this option to leave the white point at the
maximum intensity (0%), or to choose the
white point such that some percentage of the
pixels in the image are above the white point.
     The default white point is 1% (that is,
the brightest 1% of pixels are all converted
to pure white). Setting a higher value will
cause tones close to white to become pure
white. This can improve contrast and overall
intensity of the image. Setting the white
point too high will cause details in areas of
highlights (e.g. the gray puffs of a cloud)
to be lost, making the image look flat."
"Black point (%)
     The black point is used by the color
this option to leave the black point at the
minimum intensity (0%), or to choose the
black point such that some percentage of the
pixels in the image are below the black point.
     The default black point is 0. Setting a
higher value will cause tones close to black
to become pure black, which can improve
contrast. However, setting the black point
too high will cause shadow detail to be lost."
