HP B9180 = better than 2400 ?
2008-02-07 by djon43
Right/Wrong? :  HP B9180 beats Epson 2400 in *EVERY respect* ASSUMING
OEM pigments (except panoramas and perhaps metamerism on gloss)...is
that a fair conclusion?
Asked another way: using OEM pigments, are there *any* B&W arguments
in favor of 2400 or 1900, other than gloss and panoramas?
Re: [Digital BW] HP B9180 = better than 2400 ?
2008-02-07 by Ernst Dinkla
I have none of them but some time ago they were compared to
one another (+ a Canon) in a Photo-i review that also had a
page on B&W:
http://www.photo-i.co.uk/Reviews/printers/Pigs/page_1.html
Also check what the reviewer would buy of all the printers
on the market these days, at the end of the review.
Met vriendelijke groeten, Ernst
|  Dinkla Grafische Techniek  |
|     www.pigment-print.com    |
|             ( unvollendet )            |
2008-02-07 by Tony Sleep
Despite HP specs apparently limiting page length to 19", it is allegedly
possible to get the B9180 to print up to 43" using Qimage. I haven't tried
it since I don't shoot panoramas.
http://tech.groups.yahoo.com/group/hp9100Series/message/2332
I think you'll find owners of both printers who are mostly happy and a few
unhappy. 'Better than' is relative to that and personal expectations,
really. Both printers are extremely capable.
For me, because I only print intermittently but when I do I need it to
Just Work without the 3am Windex panic routine, the overwhelming virtue of
the HP is its ability to maintain nozzle health on standby, with
negligible ink usage. This does appear to do exactly what it says on the tin.
The other clearcut issue for me is not having to swap between PK and MK
inks when swapping between gloss and matte materials. I use both types and
swap between them session to session, depending on what clients want.
It makes excellent prints too, but there's no question Epsons manage that
as well. Whether or not you like the HP's black+gray only option is
subjective. It has no glaring defects (like dottiness or lack of tonal
smoothness) except it bronzes badly on non matte papers. Aesthetically I
mostly prefer composite B&W because I usually like warm prints rather than
strictly neutral, and ultimate DMax is slightly improved too, but
achieving that means tinkering with image colour rather than the elegant
Epson ABW adjustments. 	Again, Qimage helps make up for that.
I'll abstain on the 'better than', I have no regrets about getting the HP
but I'm sure most 2400 owners would say the same about their choice too.
Except maybe to wish they'd got a 3800 instead :)
Tony Sleep
http://tonysleep.co.uk
2008-02-07 by Richard Smallfield
One thing I noted in the specs is that it doesn't like papers over 270gsm. That narrows paper options considerably.
It is excellent value for money though - cheaper than the 2400 plus with a densitomiter.
BTW - what's the value of a densitomiter compared with a colorimiter?
Richard
http://smallfield.vze.com
   "A conservative is one who admires radicals centuries
   after they're dead."
   --Leo C. Rosten
2008-02-07 by CDTobie@aol.com
In a message dated 2/7/08 1:06:23 PM, r.smallfield@... writes:
While I fear this may be stating the obvious: a densitometer only measures
density, not color...
C. David Tobie
WW Product Technology Manager
Digital Imaging & Home Theater
Datacolor
CDTobie@...
www.datacolor.com/Spyder3
Biggest Grammy Award surprises of all
time on AOL Music.
(http://music.aol.com/grammys/pictures/never-won-a-grammy?NCID=aolcmp00300000002548)
It's a conservative fib. I regularly print HPR 308GSM with no issues.
Other people have printed with thicker stocks. Harman FB AL Glossy
(320gsm) curl during printing  is an issue for some people, giving head
strikes, but I've had no problems. The B9180  adjusts itself to paper
thickness but there is also a rigid media setting for board etc. that I've
not used.
The optical calibration is nothing to do with profiling, it allows the
printer to recalibrate itself to a factory-set state if anything changes
(eg new head installed) or drifts over time. This seems to be consistent
enough across B9180's that a profile that works well on one will work
equally well on any other B9180. Epson do their calibration at the factory
or at service time, with the HP it's part of set-up, or any other time it
might seem necessary.
Tony Sleep
2008-02-07 by daverich4
Hi David,
This might just be a question of semantics but I've worked in a photo lab for a long time
using a variety of densitometers. They're normally used for process control and read red,
green and blue densities. Is that something different from what you're saying?
-dave-
> C. David Tobie
> Datacolor
> CDTobie@...
> time on AOL Music.
In a message dated 2/7/08 1:35:26 PM, TonySleep@... writes:
That certainly improves consistancy, but I've yet to see it beat custom
profiling. Another reason HP does this and Epson does not, is that Epson's heads
are permanent, while HPs are replacable thus in need of site recalibration).
Epson provided (in some sections of the world) a utility that let users adjust
the printer calibration with an external patch reader, but has hesitated to put
much weight behind the method. And while its useful for making two printers of
the same model run from the same profile, its not really necessary to get
good results on a given printer, a custom profile pretty well covers that.
C. David Tobie
Datacolor
CDTobie@...
Biggest Grammy Award surprises of all time on AOL Music.
548)
In a message dated 2/7/08 2:46:04 PM, daverich04@... writes:
> Hi David,
> for a long time
> and read red,
> saying?
Reading Red, Green, and Blue densities just helps you linearize each color
channel, or   (making some dangerous assumptions) perhaps cross balance them. It
does not tell you, for instance, how saturated the red is, or if its a bit
orange, or a bit purple... that requires a color reading device, such as a
colorimeter, rather than a density reading device, like a densitometer. ICC
profiles require actual color information, not just density information. By the way,
a densitometer doesn't even know if the ramp its reading is Red, Green, or
Blue, you have to read the right strips in the right order...
C. David Tobie
Datacolor
CDTobie@...
time on AOL Music.
2008-02-08 by edknight_w
Using the straight paper path and the rigid photo rag setting, I've
successfully printed several 13x19 prints on Hawk Mountain's Nighthawk
paper(500gsm)using HP's B9180.  The specs say the straight paper path
accepts up to 1.5mm thickness.  Believe this is close to the thickness
of 4-ply matte board.   I've also printed panoramas up to 36" long.
Think prints will go to 44" on Windows, but have not yet had the need.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Tony Sleep
that I've
> not used.
changes
consistent
factory
time it
> Regards
> Tony Sleep
2008-02-08 by Tony Sleep
Yes, having RTFM a 220gsm limit applies only to the 'Main tray' - the bulk
sheet feed box. As you say, up to 1.5mm is specified for the 'specialty
media tray' - the front single-sheet feed.
Tony Sleep
2008-02-08 by Ernst Dinkla
> page on B&W:
The same printers are used for a range of papers: third
party, HP, Canon and Epson in a test published in the
February ColorFoto  issue.
http://www.colorfoto.de/kameras/testberichte/50_papiere_auf_3_druckern.155431.htm
You have to pay some Euros for a download. German however.
It is interesting to see that the B9180 is considered
compatible with 20 papers of the 50 while the Canon ends at
9 and the Epson at 10.
|             ( unvollendet )            |
2008-02-08 by daverich4
David,
That makes sense. Thanks for the clarification.
-dave-
> > Hi David,
> > for a long time
> > and read red,
> > saying?
> C. David Tobie
> Datacolor
> CDTobie@...
> time on AOL Music.
