Printing color on R800 with MIS Eboni B&W conversion
2008-02-11 by douglastourtelot
I have converted my Epson R800 to a carbon black B&W printer using
advice from Paul Roark and QTR and Eboni inks from MIS.
The B&W part works really well, and I am really pleased, B&W being
most of my printing.
But I was led to believe that I could use the remaining Epson inks to
print color "as if nothing had been changed in the R800."  I tried to
print a quick portrait of my daughter yesterday and was really
surprised to see how badly the printer did on color.  I am totally
sure that this is opperator-error, not bitching at the printer, but
what did I do wrong?  The print was really, really dark, and I am
wondering if I somehow didn't set the "glop" position to be off.  If
the printer thought that that cartridge space still had glop in it,
wouldn't it lay down MIS Eboni ink "as if" it were glop?
If anyone knows the whys and hows of printing color on this printer,
I would appreciate the advice.
Thanks.
D.
Re: Printing color on R800 with MIS Eboni B&W conversion
2008-02-11 by pr_roark
> inks to  print color "as if nothing had been changed in the R800."
Paragraph 2 of my notes on the approach states, " ... the approach is
that it allows the R800/1800 to also print full color on matte paper
with the usual Epson driver ..."
http://www.paulroark.com/BW-Info/R1800.htm
With PK and Glop removed from the usual 3-MK setup and Eboni
installed in those positinos, glossy printing is not going to work
without inks being changed.
> surprised to see how badly the printer did on color...
With most of the matte paper settings, the driver grays out the Gloss
option. So, I'm guessing you tried to use glossy paper.
>  If
Yes, that's exactly what it'll do if you select a glossy paper type
setting and check Gloss.
Basically, it's easiest to stay with matte paper for color.  Then no
inks need to be changed from the default 3-MK setup.  If you do want
to print color on glossy paper, you need to at least change the PK
position to PK.  This is easy.  If you want gloss optimizer to be
used, it's more difficult to totally flush the Eboni out of that
position.  It is not an efficient way to go.
Good luck with the setup.
2008-02-11 by rockfordinvestigations
Paul,
Isn't there a difference in color between Epson's MK and Eboni? It seems like new profiles
might be needed with this set up.
I'm about to move to color with my R1800, and I'm excited to see the results.
2008-02-12 by pr_roark
Eboni is much cooler and more neutral than Epson MK.  I've heard that
some can see cooler shadow tones.  I also notice a magenta difference
when I compare the MIS R800 M with Epson M.  I was surprised I didn't
see a major shift in just casual printing.
Whether one needs a new profile probably depends on how critical the
color printing is.  I think MIS claims it's R800 replacement inks can
use the same profiles.  For casual printing I've used them that way,
but then I don't do serious color printing.  I suspect the majority of
serious color printers make their own custom profiles.
Good luck with the system.
