Cleaning fluid for a channel not in use
2008-02-13 by met.graphix
I set up my 7600 for b&w printing. Currently I'm using 6 channels and
I'm planning to keep it this way for a while. I've just noticed though
that the 7th channel, which is not actively used, is beginning to
develop a clog. I want to remove the ink from that cart (funnel fill
type) and replace it with some kind of fluid to keep the nozzles clean
and going.
What type of fluid do people normally use in this situation?
Thx
Dario
Re: [Digital BW] Cleaning fluid for a channel not in use
2008-02-13 by Mark Savoia
The pink flushing fluid from InkjetMall works great for that, I have
it in an unused position for months.
Mark
http://www.stillrivereditions.com
> and going.
> Thx
> Dario
Re: Cleaning fluid for a channel not in use
2008-02-13 by Steven Karafyllakis
Dario;
Matte, glossy, or both? If you are set of glossy, consider using the
extra channel for Gloss optimizer!
Steve Karafyllakis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "met.graphix"
though
clean
> and going.
> Thx
> Dario
2008-02-14 by met.graphix
As a matter of fact I do have GLOP in house, as well as some of the
older MIS base. And GLOP is in the plans for down the road. In the next
few months though I'll be busy printing exclusively on matte. I thought
that GLOP may be causing some nozzle clogs if not used regularly. Is
that a valid concern?
Dario
2008-02-14 by Steven Karafyllakis
Yes, over a long period like that it is more likely to dry up on the
bottom of the head. Cleaning fluid would be better then.
Steve Karafyllakis
> I thought
> Dario
That's the question then. What's cleaning fluid???
I understand that MIS flushing fluid in just ink base. Is the flushing
fluid from inkjetmall that Mark suggested their version of ink base?
Dario
