Questions on platen gap, paper thickness and head alignment.
2008-02-14 by wwodets
After printing over 100 13 x 19 prints on the 4800 with the Harman
Gloss, just yesterday I began to have a problem.  On small areas of a
print (a couple of inches across, irregularly shaped), in darker areas,
there was a pattern of very fine straight, parallel lines in the
direction of print head travel.  Looking under a microscope it seemed
that these lines were gloss differential, not desnity differences.  The
lines cannot be seen if the print is held at a glare-free angle.
Assuming they were from the printhead very lightly scratching the
surface, I adjusted several parameters and increasing the platen gap
to "wider" (the largest setting) seems to have stopped the problem.  It
became dry here yesterday and I think the dark areas were being
saturated and the paper was warping like air-dried gelatin papers did.
So, I'm left with some questions.
1.  What is the significance of platen gap and paper thickness?  I
assume that the distance of the print head from the paper surface is
the platen gap minus the paper thickness.  I have measured the Harman
paper at 0.31 mm and have used a paper setting of "3" along with
the "wider" platen gap setting.
2.  Epson specifies doing the auto head alignment procedure with either
EEM or Premium Lustre.  Is there a reason to not do this with a gloss
paper?  With the paper that will ultimately be used for printing?
3. Is it not important to do the alignment procedure with the paper,
platen gap and paper thickness settings as they will be used for
printing?
4.  The paper configuration settings in the Epson driver allow vacume
adjustment for standard and lower settings.  The printer itself allows
a high setting while inserting a single sheet, but this is overridden
by the driver when printing.  Is there a way to use high vacume for
printing or would this prevent proper paper transport?  It seems to me
that it might suck down the warps and allow a smaller platen gap.
Any thoughts much appreciated.
Walt
Re: [Digital BW] Questions on platen gap, paper thickness and head alignment.
2008-02-15 by Andrew Darlow
Hi Walt:
One thing you should know is that if you set the printer's LCD
display to read STD, then the software driver settings for platen gap
take over. If you change it on the printer, the printer takes over.
It's interesting to scroll through some papers and then go to Paper
Configuration to see how the thickness changes. I am guessing, but I
think Epson recommends EEM or Premium Lustre for head alignments so
that you can get a generally good alignment for papers that fall into
the range of those two papers (which are most papers). Some people
might put lightweight typing paper in to run a nozzle/head alignment
check, which is generally a bad idea because sometimes the printer's
sensor can't read the lines properly. I personally would run the
alignment on the paper you plan to use if that is a paper you plan to
use a lot. Also, the Paper Thickness amount that is entered into the
box in the driver determines the platen gap setting.
My understanding with regard to suction is that Normal is the
strongest and the others are all weaker. I don't know how much the
suction adjustments will impact that paper on the 4800, but you can
try a few settings in the driver.
Hope that helps,
Andrew
Andrew Darlow
Editor, The Imaging Buffet
http://www.imagingbuffet.com
Author, 301 Inkjet Tips and Techniques:
An Essential Printing Resource for Photographers - http://
www.inkjettips.com
> areas,
> printing?
> Walt
