Preference for the 4880 over the 4800
2008-02-18 by wwodets
I'm about to spend some money servicing my 4800 and I'm wondering if
there is any real preference for the 4880.  This is BW work only, and I
am using Paul's warm carbon in the yellow position with K3 inks, so the
color gamut is irrelevant.  Anything else?
Walt
Re: Preference for the 4880 over the 4800
2008-02-19 by Steven Karafyllakis
Walt;
There is the 3rd party ink issue to consider-do either the wide
format chip resetter or the auto-reset chips work for the 4880? If
not, you'll have to drain the 4880 yellow and refill with carbon ink
until a solution comes up. Not sure that's a good enough reason to
stick to older technology, but you be the judge.
Steve karafyllakis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "wwodets"
if
and I
> Thanks,
> Walt
2008-02-19 by wwodets
Steve-
Thanks.  I looked at the Epson part numbers and the yellow cart is
the same number for the 4800 and 4880.  So I assumed that the same
third party carts, chip setters, etc. would work.  But perhaps it is
more complicated than that?
Walt
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven
Karafyllakis" <stevekphoto@...> wrote:
> Walt;
ink
> Steve karafyllakis
> if
> and I
so
> the
> > Thanks,
> > Walt
RE: [Digital BW] Re: Preference for the 4880 over the 4800
2008-02-19 by David Whistance
Walt, hang on to the 4800, after all they're built like tanks and should
last for years even in a production environment.  There will be little, if
any, benefit in print quality from the upgrade and the increased gamut from
the new vivid magenta is of no benefit for B&W.
David Whistance
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of wwodets
  Sent: 19 February 2008 16:47
  To: DigitalBlackandWhiteThePrint@...m
  Subject: [Digital BW] Re: Preference for the 4880 over the 4800
  Steve-
  Walt
  > Walt;
  ink
  > Steve karafyllakis
  > if
  > and I
  so
  > the
  > > Thanks,
  > > Walt
