problem with matte black ink sticking to transparency film
2008-02-19 by David
I'm been printing digital "positives" on transparency film to use in
making photo-polymer etching plates; similar to digital negatives, but
I'm printing positive images with black ink only at 720 or 1440 DPI,
because I want to get a dot/grain pattern that will become the "bite"
in the etching plate.
I'm been doing this on my Epson R2400, using the Quadtone RIP
software, so I can print with black only ink. I have been using the
Matte Black ink cartridge because it seems to give better opacity and
coverage for this process (I read something similar about using this
ink for digital negatives as well).
The problem is that on the transparency films I've been trying, the
matte black ink never seems to become permanent and I can smudge it
with my finger. I thought this might not be a problem if I handled the
sheets carefully, but under the pressure of the UV exposure unit
(similar to a big contact print frame but with much more pressure), it
seems the ink is getting smooshed against the plate and causing random
rings and marks to show up in the final image, especially in areas
with continuous tone.
I'm wondering if people are having success with using the Photo black
ink to print digital negatives, or if anyone has found a transparency
film that will accept matte black ink?
Any advice or suggestions would be helpful.
Best, David.
Re: problem with matte black ink sticking to transparency film
2008-02-20 by Steven Karafyllakis
David;
I'm not surprised you're having trouble keeping the ink on the film;
you really do need to use the
PK ink, and if that doesn't give you enough density try a combination
of magenta and yellow to produce red. The dark magenta in particular
can look every bit as 'grainy' as the K inks, you should still be
able to get the effect you want.
Steve Karafyllakis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "David"
but
the "bite"
and
it
random
black
transparency
> Best, David.
Re: [Digital BW] Re: problem with matte black ink sticking to transparency film
2008-02-20 by Lloyd Braddy
It's possible that you using the wrong kind of transparency film.  If the
film that you're using doesn't have a prepared layer or has a layer designed
for dye, then pigmented ink won't adhere or dry properly.  The correct type
of transparency will be slightly milky in appearance and also be tacky to
damp fingertips.
The real difference in PK and MK inks on properly prepared inkjet
transparency lies in durability of the dried ink over time.  Reports seem to
suggest that PK inks hold up a bit better.
I haven't had any problem getting matte black (or other colors of Epson OEM
inks) to stick to mylar transparency film that has been prepared for
pigmented inks.  I, also, haven't used the results for vacuum frame
printing, but since a whole industry subset has adopted inkjet technology in
the screen printing industry I would be surprised for this to be an issue.
Unfortunately I don't have any links handy to include for suppliers.  If any
of you are interested (let me know on the list) I'll follow up this email
with a couple of links for mylar transparency designed for pigmented inkjet
use.
-Lloyd Braddy
Sent: Tuesday, February 19, 2008 8:21 PM
Subject: [Digital BW] Re: problem with matte black ink sticking to
transparency film
David;
Steve Karafyllakis
but
the "bite"
and
it
random
black
transparency
> Best, David.
they are often being updated.
page.
them short.
membership without notice.
the membership.
Yahoo! Groups Links
2008-02-20 by David
Thanks Steve.
Will the magenta and yellow inks dry on the film even if the PK doesn't?
And, are you familiar with the Quadtone RIP, and if so, if I told you
my settings, could you suggest settings for the M and Y inks that
would mimic this?
Thanks, David.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven
Karafyllakis" <stevekphoto@...> wrote:
> David;
> Steve Karafyllakis
2008-02-20 by David
Lloyd, what brand of transparency film are you using? I have tried a
few where the MK worked, but the coating is so course, it doesn't pick
up the resolution that I need. All the ones made for fine art or
digital photo applications don't seem to work. I've seen a few brands
that were for dye inks and I've avoided those.
I'm not really looking at permanence as usually defined--I just want
the ink to dry and be permanent enough so I can't wipe it off with my
finger.
Regarding the difference between the two, I've read: "they're actually
the same pigment, the only difference is the photo black has a coating
around the pigment particles so it sticks to glossy/luster media."
David.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Lloyd Braddy"
Epson OEM > inks) to stick to mylar transparency film that has been
prepared for pigmented inks.
 -Lloyd Braddy
David,
Ah, resolution may still be an issue then.  I was transferring line art and
resolution wouldn't have been so obvious as with creating negs for
continuous tone photographs.
I used Inkpress transparency film.  Printing was done on an Epson 4800 with
matte black and the standard ultrachrome inks.    The Inkpress media happens
to have a multi-purpose coating which works with dye, dura-brite, and
ultrachrome inks.  Initially it was the easiest product to get in the right
size for my purpose.  Since then I've found other manufacturers that seem to
be allied with the graphic arts/screen printing industry.  Most of these
products use a microporous coating which is why you can use either dye or
pigment inkset in some cases. As long as you've chosen the proper type of
media for your inkset type, PK or MK inks seem to be somewhat
interchangeable.
With PK and MK inks, I wasn't speaking technically but referring more to the
real world end results with transparency printing - all based on anecdotal
reports...
Sounds like you've done enough experimenting to know this, but it's actually
pretty easy to print on the wrong side with transparency film and when you
do that, you CAN wipe the ink off with a finger. I usually test the
tackiness of the film with a damp finger and print on the tacky side with
good results.
Forgive the reference, but Dan Burkholder is reknown for making digital
negatives and uses pictorico transparency film.  He's alluded to PK inks
being superior, but I think that's related to D-max..(again, anecdotal).  I
have no direct experience with this transparency media since it didn't suit
my project's budget.
http://www.ppmag.com/web-exclusives/2007/07/making-digital-negatives.html
Some other internet links which might be helpful:
http://www.adorama.com/IJT172220.html  This is a link to the Inkpress media
at Adorama.
http://www.americanscreensupply.com/index.php?l=product_list&c=36  This is a
link to a Fast Positive waterproof (pigment) film vendor.
http://screenprinters.net/product.php?fk_pid=fastposfamily This link
provides product details for both the non-waterproof (dye) and waterproof
(pigment) films.  It's mostly sales stuff, but it provides more details than
just prices.
http://estore.lawsonsp.com/index.asp?PageAction=VIEWPROD&ProdID=275  Yet
another vendor of waterproof transparency media -- don't let the photo fool
you, these films all have a slight milkyness to them.
http://news.thomasnet.com/companystory/477675  This is a product that I was
interested in, but could not pursue because it was designed for DYE BASED
printing.
http://www.ulano.com/ijf/inkjetfilm.htm  Inkjet media overview for Ulano
nano-porous coated films.
I do have a continuing interest in printing on transparency so I'd
appreciate learning of your eventual results.
-Lloyd
Sent: Wednesday, February 20, 2008 10:32 AM
transparency film
finger.
David.
 -Lloyd Braddy
page.
them short.
the membership.
Yahoo! Groups Links
2008-02-20 by Ender100@aol.com
It's not unusual for some inks to not work with some films—especially Matte
Black.   Try Photo Black instead, it should solve your problem.   If you are
making digital negatives, there is an easier work around to this using color and
avoiding black altogether.   You can get better density too.   see link
below.
Best Wishes,
Mark Nelson
Precision Digital Negatives - The System
PDNPrint Forum at Yahoo Groups
www.MarkINelsonPhoto.com
Ideas to please picky eaters. Watch video on AOL Living.
(http://living.aol.com/video/how-to-please-your-picky-eater/rachel-campos-duffy/
2050827?NCID=aolcmp00300000002598)
2008-02-20 by David
Thanks Mark, right now I can't afford to buy your book, but it looks
like you have a successful system for DN. Also, I'm creating image
positives with one ink, meaning that they are made up of a series of
ink dots (similar to an aquatint), but they are not continuous tone as
you'd do for a digital negative.
That said, which ink or inks would you suggest to get the most
opaqueness or UV blocking capacity (on the Epson R2400)?
Regards, David.
filmsâ€"especially Matte
you are
using color and
> below.
> Best Wishes,
> Mark Nelson
Hi David,
For the R2400 "Green" ink gives the most density.   This is usually true.
Black inks in the new printers are very weak.
Are you making negatives for polymer plate?
I've been experimenting with polymer plates for photogravure and PDN is
producing really good results using the KM73 plates from Boxcar Press.
Best Wishes,
Mark Nelson
In a message dated 2/20/08 5:33:59 PM, dkfreed@... writes:
> Regards, David.
2008-02-21 by David
Thanks again Mark.
How would I create the green ink? I'm using Quadtone RIP to control
the printer and give me control over which inks I'm using. I assume I
could select only the yellow and cyan ink, but I'm not sure how to
create a curve where these inks would be "mixed" in each dot.
Yes, I'm using these for photo polymer etching. And I'm making my
plates with ImagOn film.
Best, David.
> Hi David,
true.
