is pearl considered to be a matte or glossy paper?
2008-02-28 by c1asia
is the ilford premium photo pearl a matte or a glossy paper? per the R1800, should i use gloss optimizer on this paper?
2008-02-28 by pr_roark
> is the ilford premium photo pearl a matte or a glossy paper? per the > R1800, should i use gloss optimizer on this paper? > The Ilford Galerie Smooth Pearl I've used is a "glossy" paper that requires PK. Paul www.PaulRoark.com
2008-02-28 by Gary Weaver
I don't know this paper, but you have to try and understand the terms. First, it's "Photo" - usually gloss resin type. Second, it's Pearl - an attempt to tone gloss down. I'm using up some Kodak Pearl that is a far cry from matt. I only have Quadtone (MATT inks) inks and they come out "good" on my Pearl. gar *********** REPLY SEPARATOR ***********
On 2/28/08 at 6:42 PM c1asia wrote: >is the ilford premium photo pearl a matte or a glossy paper? per the >R1800, should i use gloss optimizer on this paper? > > > >Please visit the Group Homepage to check the Files, and other resources as >they are often being updated. > >http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > >If you wish to receive no emails or just a daily digest, or you wish to >unsubscribe, please edit your Membership preferences by visiting this same >page. > >Please follow these basic guidelines: >- As threads develop, trim off excess portions of earlier messages to keep >them short. >- Good manners are required at all time. No personal attacks or flames. >Hostile, aggressive or argumentative users may be removed from the >membership without notice. >- Keep your posts and threads related to the group topic of digital B&W >printing. Users who persistently make off-topic posts may be removed from >the membership. >- By posting on this forum you agree to abide by the group rules and >guidelines, and to abide by the actions and decisions of the group Owner >and Moderators. See Group Topic, Rules and Guidelines in the Files >section: >http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ > >BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT >YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE OWNER AND >MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO >YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR >EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF >PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE >OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN >ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE >OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) >UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) >STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT >YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE >PRINT YAHOO GROUP. > >Yahoo! Groups Links > > >
2008-02-29 by c1asia
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "pr_roark" <pr_roark@...> wrote: > > > > is the ilford premium photo pearl a matte or a glossy paper? per the > > R1800, should i use gloss optimizer on this paper? > > > The Ilford Galerie Smooth Pearl I've used is a "glossy" paper that > requires PK. > > Paul > www.PaulRoark.com > this particular paper is not the galerie paper. i'm never quite sure about papers with the pearl, luster, satin, and semi-whatever finish designation. i'm guessing they all fall under glossy (with maybe the exception of semi-matte) but i'm not 100% sure whether to use gloss optimizer or not and whether to use PK or MK on the K3 inks.
2008-02-29 by run4alife@aol.com
what is gloss optimizer? **************Ideas to please picky eaters. Watch video on AOL Living. (http://living.aol.com/video/how-to-please-your-picky-eater/rachel-campos-duffy/ 2050827?NCID=aolcmp00300000002598) [Non-text portions of this message have been removed]
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, run4alife@... wrote: > > what is gloss optimizer? > > > http://www.publishingperfection.com/epson/eps530/
2008-02-29 by pr_roark
> > what is gloss optimizer? > http://www.publishingperfection.com/epson/eps530/ The Epson Gloss Optimizer for the R1800 & R800 is a clear ink that may have clear acrylic particles in it but is, by weight and not counting the water, mostly glycerol. It basically fills in between the color pigments so that bare paper does not show through, helping to eliminate gloss differential and some of the other reflective artifacts that have plagued glossy digital printing. The MIS Gloss Optimizer is essentially the glossy base with no pigments. It can be used the same way as the Epson version, but we are also using it as a clear coat. A post-printing spray like Premier Art Print Shield has been the best way to eliminate the glossy artifacts and protect glossy prints, but a number of us are experimenting with Gloss Optimizer (often referred to as "GO" or "Glop") as a coating for glossy prints, running the print through the printer a second time to apply an even, clear over coat. This often increases the dmax and eliminates most of the artifacts. At this point I still consider it an experimental workflow, but some of the results are very good so far. Paul www.PaulRoark.com
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "pr_roark" <pr_roark@...> wrote: > > > > > what is gloss optimizer? > > > http://www.publishingperfection.com/epson/eps530/ > > The Epson Gloss Optimizer for the R1800 & R800 is a clear ink that may > have clear acrylic particles in it but is, by weight and not counting > the water, mostly glycerol. It basically fills in between the color > pigments so that bare paper does not show through, helping to eliminate > gloss differential and some of the other reflective artifacts that have > plagued glossy digital printing. > > The MIS Gloss Optimizer is essentially the glossy base with no > pigments. It can be used the same way as the Epson version, but we are > also using it as a clear coat. A post-printing spray like Premier Art > Print Shield has been the best way to eliminate the glossy artifacts > and protect glossy prints, but a number of us are experimenting with > Gloss Optimizer (often referred to as "GO" or "Glop") as a coating for > glossy prints, running the print through the printer a second time to > apply an even, clear over coat. This often increases the dmax and > eliminates most of the artifacts. At this point I still consider it an > experimental workflow, but some of the results are very good so far. > > Paul > www.PaulRoark.com > what kind of effect do you get applying Glop to matte papers? how does one set up a print job to do this second over coat of Glop?
2008-03-01 by David Logan-Morrow
with the Epson R2400 I use the luster setting and get fine results. --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "c1asia" <c1asia@...> wrote:
