Reset K7 carts?
2008-03-16 by hflockwood
Jon, Is it possible to reuse the K7 carts from Inkjetmall by refilling from the bottom, then using a chip resetter? Harry
2008-03-17 by Jon Cone
All K7 cartridges are designed for refilling. The usual method is to use a syringe and the vacuum method through the small silicon plug on the top of the cartridge through which we initially fill the cart. Temporarily tape over the vent hole. Fill a clean syringe with about 15ml of ink, insert it into the cart, draw out a vacuum, replace the vacuum with the contents of the syringe. It may take more than one attempt due to the introduction of foamy ink. But, if you draw your vacuum slowly through the ink in the syringe, or invert the cart so it does not draw through the ink, you should be able to replace the vacuum without introducing foam. Any foam will go away with an hour anyway. Then reset the chip, remove the tape and away you go. Most of our carts hold 21ml ink, but EPSON chip readers in their printers will not allow more than the use of about 14ml. So you should be refilling a cartridge which still has some ink contents. This unfortunately is normal. Jon --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "hflockwood" <hflockwood@...> wrote: > > Jon, > > Is it possible to reuse the K7 carts from Inkjetmall by refilling from the bottom, then using a
> chip resetter? > > Harry >
2008-03-17 by Michael T. Murphy
Jon, Would your empty 220ml carts be useful as cleaning/flusing carts to use with your cleaning fluids? The procedure to refill those is a bit different than the smaller carts, but still the same basicn principle. I have some adapters to use with a syringe to first fill them with water to clean them out, then to refill them. There would probably be a little bit of remaining ink, but mostly flush fluid. Any limitations to using the carts to flush with any specific pre-existing ink sets - Ultrachrome, dyes, etc? I think you are 100% on the right track with your focus on the ecological impact of the use of pre-filled carts from Epson, etc. I have 2 sets of 220ml refillable carts for my 2 Epson 7600's. I am planning to migrate one of the 7600's to the Cone Color inks. I will probably substitute the neutral K7 blacks as mentioned in another thread (instead of the greenish Epson match ones), as I have to create new profiles anyway. I do have an i1 spectrophotometer. Guess I'll have to wait a bit for a Vivid Magenta match for my 7880? ;>) Thanks! Best, Michael
2008-03-18 by Jon Cone
Michael, I would think that you should flush them first with distilled rather than tap so you do not introduce material that ends up clogging your dampers. My country water for example, could never be used. It has way too much mineral content in it. But it sounds like your plan will work well. Jon --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Michael T. Murphy" <uriel_bear@...> wrote:
> > Jon, > > Would your empty 220ml carts be useful as cleaning/flusing carts to > use with your cleaning fluids? > > The procedure to refill those is a bit different than the smaller > carts, but still the same basicn principle. I have some adapters to > use with a syringe to first fill them with water to clean them out, > then to refill them. > > There would probably be a little bit of remaining ink, but mostly > flush fluid. Any limitations to using the carts to flush with any > specific pre-existing ink sets - Ultrachrome, dyes, etc? > > I think you are 100% on the right track with your focus on the > ecological impact of the use of pre-filled carts from Epson, etc. > > I have 2 sets of 220ml refillable carts for my 2 Epson 7600's. I am > planning to migrate one of the 7600's to the Cone Color inks. I will > probably substitute the neutral K7 blacks as mentioned in another > thread (instead of the greenish Epson match ones), as I have to > create new profiles anyway. I do have an i1 spectrophotometer. > > Guess I'll have to wait a bit for a Vivid Magenta match for my > 7880? ;>) > > Thanks! > > Best, > Michael >
2008-03-18 by Michael T. Murphy
Thank you Jon! I am glad I asked. Sometimes the questions seem obvious, but I would not have used distilled water. Good point! We are on a well, lots of iron, etc. Thank you for sharing here. Best, Michael
2008-03-18 by Harry Lockwood
Thanks, Jon. Harry -- Harry F. Lockwood
