epson 3800
2008-03-21 by deandadin
Anybody know if you can print panoramics with the 3800 printer using print with photoshop. I am interested in printing 16x32 panos with the 3800 through photoshop. Will Photoshop support this? Thanks Steve
2008-03-21 by John Vitollo
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "deandadin" <deandadin@...> wrote: > > Anybody know if you can print panoramics with the 3800 printer using > print with photoshop. I am interested in printing 16x32 panos with the > 3800 through photoshop. Will Photoshop support this? Thanks Steve Yes.... using the Epson driver maximum print length is around 37"....more if using a RIP.
2008-03-21 by deandadin@aol.com
Hello again, What if you are just printing through Photoshop without a rip.
Will Photoshop support panoramic prints with a 3800? thanks
Create a Home Theater Like the Pros. Watch the video on AOL Home.
(http://home.aol.com/diy/home-improvement-eric-stromer?video=15?ncid=aolhom00030000000001)
[Non-text portions of this message have been removed]2008-03-21 by John Vitollo
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, deandadin@... wrote: > > Hello again, What if you are just printing through Photoshop without a rip. > Will Photoshop support panoramic prints with a 3800? With Photoshop and Epson driver 37" is the max. Here's some links for you...Eric's is the best resource for the 3800: http://people.csail.mit.edu/ericchan/dp/Epson3800/faq.html#longest http://www.inkjetart.com/Epson_3800_Pro/
2008-12-29 by Antonio Fernandez
well, my espon 1280 finally died. does any one have experience with an epson 3800 printer for printing black and white photos? thanks in advance for information.
2008-12-29 by detlef_g
HI, I´m using the 3800 mostly for printing B&W with the original Epson K3 inks. The printer was recommended on a printing seminar from one of the best German B&W printer i knew (Rolf Walther, http://www.walther-fineart.de/) I´m very happy with the results i get out of the epson. Detlef --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Antonio Fernandez" <tlaloc_aif@...> wrote:
> > well, my espon 1280 finally died. does any one have experience with an > epson 3800 printer for printing black and white photos? thanks in > advance for information. >
2008-12-29 by Antonis
Antonio, the 3800 (and similar in the Epson range) offers an ABW mode in the driver that works very well. I have only used it to produce so-called "glossy" B&W prints and I am very happy with it. Assuming your monitor and workflow is accurately profiled/color-managed, you won't need any profiles to use any of the current fiber based semi gloss papers. I have not tried it (yet) for matte papers. Now, having said all that, here is a broader perspective: With the 3800 and ABW you get maximum convenience (mine was perfectly linearized out of the box) and a very decent B&W print quality. Good enough to hang and to sell. But it does not represent the ideal in digital B&W printing. Here is a short list of the reasons for that: - Using OEM inks means you have full color dots mixed in with your grays. - The Epson ABW driver offers very limited control of tone across the scale. Even other drivers that break up the gray scale in three parts and control color separately in each don't come close to what a true grayscale RIP could do. - Down the line, after the Epson 3800 has been used for a while - maybe a year - I don't know if it will hold its linearization as well as it does when new. If that happens, the ABW driver offers no way to re-linearize. - Producing a grayscale out of a black and two grays is inferior to using several shades of gray, even if the dot size is as small as current technology. - The 3800 (unlike its bigger/newer brothers) does not offer pressurized carts. I don't know how this will affect consistency over the long run. - The 3800 uses relatively small carts, making ink more expensive if you produce large volumes of prints. The 4xxx line may cost more and take up more room but will be cheaper in the long run. - The 3800 offers only partial convenience in swapping matte Black and glossy Black. Both carts are installed but when you swap, you need to wait and waist some ink while the printer purges the line that is common to both inks. As a final note, consider the 17" Canons too. They are bigger and cost more but are faster and having more primary colors on hand gives them an edge if you ever need to run color prints. I believe they have separate lines for the two Black inks. They do have an ABW mode as well as a dedicated B&W RIP available. The Lucia inks have similar life expectancy as the K3. Choosing one over the other is a matter of your budget and space as well as the kind of use you have. I found my 3800 as a refurb at the Epson site for under a grand. Considering my low volume, semi-glossy-print needs and lack of space, it fit the bill perfectly. Your mileage may vary.... Antonis --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Antonio Fernandez" <tlaloc_aif@...> wrote:
2008-12-30 by Platinum Jim
I have had an Epson 3800 for about a year. Without any other software, I have been printing B&W images using the Epson ABW function in the printer driver and adjusting the color. I have also used Spyder 3 Print to make extended gray *.icc profiles to print B&W to great effect. In fact, I just finished printing as a Christmas gift for each of my children a book of images, more than 50, most in B&W. Worked like a champ. Love this printer! Jim
----- Original Message ----- From: Antonio Fernandez To: DigitalBlackandWhiteThePrint@yahoogroups.com Sent: Monday, December 29, 2008 10:28 AM Subject: [Digital BW] epson 3800 well, my espon 1280 finally died. does any one have experience with an epson 3800 printer for printing black and white photos? thanks in advance for information. [Non-text portions of this message have been removed]
2008-12-30 by punk_investor
I've been working with the Epson 3800 for about a month now, and all I can say is WOW! Now granted, it's my first pigment-based printer, but the output I get through Lightroom's Print module using Epson's ABW function is stunning. I've printed on rag and semigloss, and both provided stunning results. If you want to make a more informed decision before dropping the thousand+ bucks, see this website: http://people.csail.mit.edu/ericchan/dp/Epson3800/index.html Hope this helps. Jason --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Antonio Fernandez" <tlaloc_aif@...> wrote: > > well, my espon 1280 finally died. does any one have experience with an
2008-12-31 by digikdm
Ep 3800 produces great B&W prints. You won't be dissappointed. --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Antonio Fernandez" <tlaloc_aif@...> wrote:
