R800 Vs. R220 Black and White w/ MIS Ink
2008-03-26 by tim4peace2001
Hello. I am printing B&W with an Epson 220 with MIS B&W inks. I am
very pleased with the results. Would I notice an improvement in the
quality of prints if I was to use an R800 using the Multi-Channel 100%
Pure Carbon ink method as per Paul Roark? Would I be able to use a
larger variety and thicker paper with the R800? Thank you.
Francis
Re: R800 Vs. R220 Black and White w/ MIS Ink
2008-03-26 by pr_roark
The 220 with the MIS R2 inks probably makes smoother B&W  prints than
the 800 3MK would.  The 3MK was, in part, an effort to get the color
inks out of the mix.  Whether having color inks in the image is a
concern probably depends on whether you're intent is to make the most
stable long term prints (like for genealogy or museum reproductions
that I do), or you simply want good B&W prints that will have a
reasonably long life -- which the 220 and the MIS R2 inks can certainly
do well.
I found the R800 I had for a while to be terrible with thick paper.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "tim4peace2001"
> Francis
