Best inkset for Epson 9600?
2008-04-17 by Joost Horsten
As a print studio in my neighbourhood is offering their Epson 9600
for sale I'm of course very much tempted ;-)
Before deciding on it, I'd like to understand my options for the
inkset. I'm currently running an Epson 2100. I think this is in print
quality very similar to an Epson 9600: same inks, same dot size. But
on my 2100 I use a blended inkset (UT3D) which will not be a good
choice for a large format printer.
I'm afraid I can't count on an option that leaves colour prints open:
in the 7-color ink setup that would leave me with just 2 blacks.
So if I would go for a B&W dedicated setup, it looks like I have the
choice between a 4K+ one hand and either Cone or a Eboni/Carbon-6 on
the other. For reasons of economy the Carbon-6 is the most attractive
one. But the possibility of the 4K+ set to get true neutral effects
on a wider range of papers is very much appealing as well.
Any opinion on this is appreciated.
Joost
RE: [Digital BW] Best inkset for Epson 9600?
2008-04-17 by David Whistance
Joost
Why not try one of the Cone sets.  They are a little more expensive, however
not that bad with the larger cartridges - you could also go for refillables
and bulk inks.  The QC is very good and I have suffered no clogging here in
the UK.
David Whistance
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of Joost
Horsten
  Sent: 17 April 2008 18:44
  Subject: [Digital BW] Best inkset for Epson 9600?
  Joost
Re: Best inkset for Epson 9600?
2008-04-18 by met.graphix
> Joost
FWIW I've been using a 4K+ setup with MIS inks with a 7600 and I'm more
than satisfied with the results.
Dario
Re: [Digital BW] Re: Best inkset for Epson 9600?
2008-04-18 by Mark Savoia
You can also do two different hues (example selenium and sepia) and a
shared black position. Then you can get two printers out of one. You
will need a RIP to drive it, like StudioPrint.
Mark
http://www.stillrivereditions.com
>> Joost
> more
> Dario
