Epson R1800 clogs
Epson R1800 clogs
2008-04-22 by Myron Gochnauer
Last year I purchased an Epson R1800 for use as a "pure carbon"
printer (3 MK).
Then about three months ago I splurged for an Epson 4880.
The R1800 sat unused for a month or so as I experimented with the
4880, and when I came back to it, several colors were clogged.  No big
deal, I thought. That happened with a 2200 as well, and a few cleaning
cycles and/or Windex overnight and/or pigment-less cleaning cartridges
always put it right.
With the R1800 I had a dreadful time cleaning the heads. It took me
nearly two weeks of cleaning. soaking, sitting, cursing, threatening
etc. to get it more-or-less working again.
The questions:
1)  Have others had unusual difficulties cleaning the heads with 1.5
picoliter droplets?  I would *guess* that some of the difficulty is
related to the smaller dot-size-possibility with the R1800 (in
comparison with the 2200, C86 and similar "older" versions).
2) If you are using the 3-black version of printing, how do you test
and clean the third black... the one in the "glop" position?  The
usual head test does not print a test pattern of that position.   Does
anyone have an efficient alternative head test?
3) Does anyone know whether the Epson cleaning cycles clean the "glop"
position?
Myron
Re: Epson R1800 clogs
2008-04-22 by pr_roark
Which color inks did you have in the 1800?
I have not had any clogging issues, but, nonetheless, I've set mine
up now with Eboni in C, MK and PK, and cleaning fluid "insulatore"
next to the 3 Eboni positions.
Because I do want to continue to experiment with the glossy papers
and 100% carbon printing, I also have MIS Pro PK in the Y position
and glop in the GO and Blue spots.  This leaves one space on each
side of the Eboni spots for cleaning fluid.  I think there may be
some value in separating the high load MK from the glossy ink and
glop, which obviously have a fair amount of binder in them.
The GO position is just like a color position with respect to
cleaning.  For nozzle checks, the checkerboard pattern seems to
indicate how it is performing, though I am clueless as to how it does
so.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Myron Gochnauer
> printer (3 MK).
big
cleaning
cartridges
me
threatening
> The questions:
1.5
is
test
Does
the "glop"
> position?
> Myron
2008-04-23 by i_3d_c
my r1800 is horrible, clog-wise. i can't wait for the day i can dance
on its grave. running cleaning cycles actually makes mine worse. every
week to ten day i have to typically spend two days cleaning.
i'm pretty sure all channels get cleaned during a cycle, regardless.
sometimes i run out the quadtonerip calibration image to check/purge.
(after soaking the head, i sometimes get a bit of contamination from
the pads in the head-park area.)
> printer (3 MK).
> The questions:
> position?
> Myron
2008-04-23 by gochatunbdotca
I'm using MIS inks, with all of the colors "normal".  Eboni is in MK, PK and GO.
So lineup, from left to right is as follows? ---
Normal:  Y       M     C      MK   PK     R     B       GO
You:         Pk     cln   Eb    Eb    Eb     cln   GO   GO
