Tom, Do not panic. There are fewer people on the list over the
weekends. I'm sure Paul will respond at some point. But, if you get
QTR you'll find it very user friendly. I, too, have a 1280 using the
UT2 inkset which I will eventually convert to the EB6 inkset down the
road. Right now I'm using QTR with the 1280 carbon profile as it
comes from QTR. The best thing is that Photoshop is not needed. The
image editor you use need only be capable of saving your file or a
copy of your file as an 8-bit, grayscale, TIF file. It handles the
rest itself. You can download the QTR program for evaluation first
since it's shareware. Purchasing it gets you unlimited upgrades and
support.
Good Luck...Mike
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "garrett.tom30"
<garrett.tom30@...> wrote:
> --- In
> <garrett.tom30@> wrote:
> > Hi Guys/Gals,
> > Although I'm an old guy I have been doing digital for about 10
Yrs.
> > I have not had good experience with B&W so, after reading about
> Paul's
> > B&W printing, I've converted my old 1280 with MIS EB6 inks. Got
> set up
> > yesterday and have run a couple of test prints and am pleased
with
> what
> > I see even though some adjustments need to be made. I've read
most
> of
> > Paul's stuff but must admit that curves and other stuff is over
my
> > head. What I need to know at the moment is;
> > Are there profiles or something similar that will allow a more
> > consistant output without lots of test prints and trial and error
to
> > adjust brightness and contrast assuming use of the same paper?
> > Does QTR provide help in that area? Any advice will be greatly
> > appreciated. Thanks
> > Tom
> It appears that this question is being disregarded anyway but I just
> wanted to say that I have done some reading and believe I now better
> understand what I need to do so no reply is necessary.
> Tom
