Thank you Kip and Paul.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Kip Babington
<cbabing3@...> wrote:
> I started with the C84s and EZ inks, and when those ran out at the
Epson
> Clearance center I switched to C88s. They took the same cartridge
but a
> different chip (although my CIS worked on both without changing
chips.)
> When it was time to get another C88 (I like to keep a spare on
hand) it
> looked like all Epson had were the 88+ models, and I called MIS to
see
> if there was a problem. Was told the same cartridges and chips
worked
> in both models. As it turned out the next one I got just
said "C88"
> without any plus mark, so I'm not sure if it was a + model or not.
> In any event, on the Epson site, the same cartridge numbers are
> specified for both printers.
> Cheers,
> Kip
> pr_roark wrote:
> > > .. will MIS
> > > EZ Ultratone Cartridges work as readily and as well with the
Epson
> > > C88+ as with the C88? Any modifications necessary?
> > I believe MIS EZ will run the same on the C88+ as on the C88.
Frankly,
> > I'm not sure if there are any significant differences between
those
> > models.
> > Paul
> > www.PaulRoark.com
