Cleaning carts needed when switching from OEM to Eboni?
2008-07-07 by Paul Whiting
I'm trying to set up my R1800 with Paul Roarke's 3MK approach. Do I need cleaning cartridges or not? I'm seeing what appears to be conflicting information on the MIS website. I still have the OEM carts in the R1800 and plan to replace the PK, MK, and GL positions with Eboni ink. I've capitalized the parts that seem to disagree. 1) on this page http://inksupply.com/epsonclean.cfm I read this: Purging Desktop Printers Cleaning cartridges for Epson printers are not normally required on Desktop printers before installing MIS inks. However, if you have been using inks from another 3rd party, like Lysonic, you must purge this other ink from the printer before installing the MIS ink. IF YOU HAVE HAVE ONLY HAD EPSON INK IN THE PRINTER, CLEANING CARTRIDGES ARE NOT NECESSARY. This does not apply to Continuous Flow Systems. A new cartridge set is required to change inks on a CFS. 2) but on this page: http://inksupply.com/R1800_bo.cfm I read this: The full color cartridge set is offered here for your convenience, and are exactly the same as our MIS cartridges for the R800/R1800 printers. If you are currently using R800/R1800 inks that are not OEM we recommend switching to Inksupply.com color inks to avoid ink compatibility issues. ADDITIONALY, WE STRONGLY RECOMMEND THAT YOU USE CLEANING CARTRIDGES TO CLEAR INK FROM THE LINES PRIOR TO THE USE OF EBONI and before switching back to the original Photo Black and Gloss Optimizer cartridges. --------------- Maybe what makes the difference is using Eboni... Thanks again, everybody.
