Epson 2100 - Matt and Photo Balck in printer simultaneously
2008-07-07 by giuseppe_toffoli
Hi guy, I use QRT with excellent results in my Epson 2100 + UltraChrome.
Befor change with carbon ink, I want finish UltraChrome. Since the
magenta is not used in the prist process with QTR, I can replace the
maganta with PHOTO black. If yes, I must change the profile with the
new position about photo black, it's right?
Thank's very much
Giuseppe Toffoli from Italy
Re: Epson 2100 - Matt and Photo Balck in printer simultaneously
2008-07-08 by Joost Horsten
Hi Giuseppe,
What you are proposing should possible. As a matter of fact if you do
so, you start recreating a derivative of Paul Roark's 4K+ ink setup:
http://www.paulroark.com/BW-Info/4K+.pdf
It may be worth considering to go all the way along this path.
Joost
--- In
DigitalBlackandWhiteThePrint@yahoogroups.com, "giuseppe_toffoli"
UltraChrome.
> Thank's very much
