Epson 1280 clogs
2008-07-19 by esharamaki
I'm about at the end of my rope with my 1280. I've tried windex on the pad. I've tried using ink base in the cartridges and running multiple cleaning cycles. I've tried just printing lots of documents. Any last suggestions before I recycle my 1280? Thanks, Earl
2008-07-20 by Tony Sleep
On 19/07/2008 esharamaki wrote: > I'm about at the end of my rope with my 1280. I've tried windex on > the pad. I've tried using ink base in the cartridges and running > multiple cleaning cycles. I've tried just printing lots of documents. > > Any last suggestions before I recycle my 1280? It may just be badly clogged but the microfilters in the head eventually clog - especially using pigments - and at that point you can try flushing them but most likely a new head is needed. See http://www.mwords.co.uk/catalog/articles_info.php?articles_id=106 for some heavy-duty cleaning ideas. You can try cleaning the filters by small pump-suck actions with the syringe. It didn't work for me. Blocked filters are indicated by nozzle checks returning varying nozzles not working. The ink isn't getting into the heads adequately. New heads are about 80GBP (~165USD) if you fit it yourself, a fairly easy 10minute job if you're handy at that sort of thing, just screws, plastic clips and connectors. There is no 'engineering alignment' procedure on this printer unlike some Epsons so it's straightforward. However it will happen again eventually. I had this happen with both an 1160 using Piezo BW and 1290 using G4 CIS. I gave both mine to an optimist when the second heads appeared to be going the same way. -- Regards Tony Sleep http://tonysleep.co.uk
2008-07-20 by esharamaki
Thanks for the link Tony. I decided to send it off to the recycler. Ever since I got it, it's had problems with clogging. So, now I have one less clogging problem to worry about!
2008-07-20 by Andrew Darlow
Hi Earl: With the printer on, press the yellow button under the cover as if you were going to change an ink. Then pull out the plug which will allow the printhead to move back and forth. Then take a paper towel, fold it over a few times, soak it with windex and tape it down to the center area of your printer under where the head travels/. Move the head with your hand back and forth over it. You should see a lot of "gunk" come off. Return head to right side. Plug in printer. I know you said that you tried Windex on the pads, but after the procedure above, you might want to use an eyedropper and soak the cleaning pad area where the head rests with about 10ml of Windex or similar product. Then return the head to the right and wait about 10-24 hours. Then fire it up and give it a try. Hope that helps, Andrew --------------------------------------------------- Andrew Darlow Editor, The Imaging Buffet http://www.imagingbuffet.com Author, 301 Inkjet Tips and Techniques: An Essential Printing Resource for Photographers - http:// www.inkjettips.com On Jul 19, 2008, at 2:09 PM, esharamaki wrote: > I'm about at the end of my rope with my 1280. I've tried windex on > the pad. I've tried using ink base in the cartridges and running > multiple cleaning cycles. I've tried just printing lots of documents. > > Any last suggestions before I recycle my 1280? > > Thanks, > Earl > [Non-text portions of this message have been removed]
2008-07-20 by robert49brake
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Andrew Darlow <ad@...> wrote: I'll second Andrews method only I use a heavier blue "shop towel", (less lint). I inherited an r1800 that had been helplessly clogged by a leaking CIS. The parking pads were gummed up with thickened ink, the bottom of the head would sit down into the thickened ink on the pads and re-clog immediately. As well as running Andrew's method see If you can locate the tube leading from the parking pad and try inserting a syringe into the tube. After soaking the parking pad with Windex keep sucking the residue out with the syringe until it is cleaned of all the gummy stuff. The 1800 I revived has worked flawlessly since then. I've even left it for a two month long stint and all it needed was a couple of cleaning cycles and it was right back on its feet.
On 20/07/2008 esharamaki wrote: > Thanks for the link Tony. I decided to send it off to the recycler. > Ever since I got it, it's had problems with clogging. So, now I have > one less clogging problem to worry about! Probably wise. Both my 1160 and 1290 were used with CIS from new. Initially they just worked. After a year or so I spent more and more time trying to get them working reliably. By 2yrs I'd replaced the head on the 1290, and it was actually far better than the OE had ever been. But within another year it had degraded and I was spending 4 times as long trying to get it working as printing, and wasting 80% of ink and considerable amounts of expensive paper. Possibly this was partly my fault as I'd quite often go a month or so without printing at all, but when I did need to use them it was usually on deadline. I got fed up with the utter unreliability, being up half the night covered in ink and Windex, or having to send printing out because I couldn't fix the damn things. I never got on with Cone BW ICC after the original plugin was ditched and inkset changed for legal reasons. I just couldn't get the same print quality with the revised stuff. Since then, JC has said the 4ink 1160 was pretty poor anyway with BW ICC. I wish he'd said that before selling me the compulsory 'upgrade'! I since bought an HPB9180, which cost 35% the price of the Epsons + CIS, and so far, at 8m old, has been no trouble at all. It just works. I never need to do a nozzle check even when left unused for a month, thamks to its daily self-clean maintenance cycle - which BTW uses almost no ink as it only cleans problematic nozzles. I did think about a 3800, but my Epson clog traumas and the ludicrous PK/MK swap regime put me off. -- Regards Tony Sleep http://tonysleep.co.uk
2008-07-20 by Richard Smallfield
At 05:41 a.m. Monday 21/07/2008, you wrote: >I since bought an HPB9180, which cost 35% the price of the Epsons + CIS, >and so far, at 8m old, has been no trouble at all. It just works. I never >need to do a nozzle check even when left unused for a month, thamks to its >daily self-clean maintenance cycle - which BTW uses almost no ink as it >only cleans problematic nozzles. I did think about a 3800, but my Epson >clog traumas and the ludicrous PK/MK swap regime put me off. Hi Tony, you don't have to swap MK/PK with the 3800. The HP is interesting, but there are two things that make me hesitate about this printer: 1. BW can't be toned in the driver. 2. No LLK, only Light Gray (same as Light Black?) How have you found these features impact on your BW printing? Richard -- richard smallfield photography http://smallfield.vze.com http://www.photoforum-nz.org/gallery/thumbnails.php?pageID=19&showID=50 "We are more easily led part by part to an understanding of the whole." --Lucius Annaeus Seneca, the Younger 4 B.C. - A.D. 65 [Non-text portions of this message have been removed]
2008-07-20 by Gary Weaver
Folded paper towel on the platen, dampen with cleaning fluid, park heads there and do a little back and forth scrubbing. Let sit. The only thing that restores my 1270. gar *********** REPLY SEPARATOR ***********
On 7/19/2008 at 6:09 PM esharamaki wrote: >I'm about at the end of my rope with my 1280. I've tried windex on >the pad. I've tried using ink base in the cartridges and running >multiple cleaning cycles. I've tried just printing lots of documents. > >Any last suggestions before I recycle my 1280? > >Thanks, >Earl > > >------------------------------------ > >Please visit the Group Homepage to check the Files, and other resources as >they are often being updated. > >http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > >If you wish to receive no emails or just a daily digest, or you wish to >unsubscribe, please edit your Membership preferences by visiting this same >page. > >Please follow these basic guidelines: >- As threads develop, trim off excess portions of earlier messages to keep >them short. >- Good manners are required at all time. No personal attacks or flames. >Hostile, aggressive or argumentative users may be removed from the >membership without notice. >- Keep your posts and threads related to the group topic of digital B&W >printing. Users who persistently make off-topic posts may be removed from >the membership. >- By posting on this forum you agree to abide by the group rules and >guidelines, and to abide by the actions and decisions of the group Owner >and Moderators. See Group Topic, Rules and Guidelines in the Files >section: >http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ > >BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT >YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE OWNER AND >MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO >YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR >EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF >PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE >OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN >ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE >OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) >UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) >STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT >YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE >PRINT YAHOO GROUP. >Yahoo! Groups Links > > >
2008-07-21 by Tony Sleep
On 20/07/2008 Richard Smallfield wrote: > you don't have to swap MK/PK with the 3800. ? Every source I've seen indicates PK and MK are not available simultaneously and must be swapped to suit the media. > The HP is interesting, but there are two things that make me hesitate > about this printer: > 1. BW can't be toned in the driver. That's true, there is no ABW equivalent. There are two B&W modes, Black & gray only, and composite. Of course if you want toned results you can print as RGB. Each method has limitations. - black and gray only : utterly neutral image colour, no metamerism, but really only works on matte papers such as HPR. Back-to-back with Cone Piezo BW ICC from my old 1160, the HP has far better Dmax and (amazingly) smoother tones, especially in the lighter values. The old Cone plugin was good there, but 4-ink BW ICC is obnoxiously 'dotty'. On semi- and gloss- bronzing is quite bad, although can be almost totally cured by overcoating with lacquer, but Cone inks didn't work at all except on matte. The bigger, costlier Z3100 adds a second gray amd Glop, and works extremely well on surface such as Harman FB AL gloss, producing the closest to un-ferrotyped gloss bromide that I've seen from any inkjet. There is however a slight lack of depth that comes from the image sitting 'on' the paper. Where black+gray mode loses out is the neutrality, which to my taste is just a touch clinical. I printed bromide for 30 years in the darkroom, and no bromide was ever quite that neutral, nor did I want it to be. Dmax is very good, but not quite good enough IMV. - composite mode adds a small amount of colour, which increases DMax significantly and is really nice, improves compatibility with gloss and semi- surfaces to the extent that bronzing becomes a non-issue, and also introduces some metamerism and gloss differential. Nothing is perfect! That bothers some people but I don't find it too bad. Anyone who printed bromide knows that was metameric too, diverging from neutral in some illuminants, eg warmish bromides would often veer toward olive green unless toned. However, there is no ability to change the tonal colour, no ABW equivalent. That's quite limiting. - B&W as RGB. For me this is the exciting and interesting bit about the HP. I am able to quadtone images and print as RGB to get extremely close to selenium-toned 1970's Agfa Record Rapid (before Agfa took out all the noxious Cadmium and ruined it). That was my favourite paper of all time, utterly sensual to print and look at. What metamerism there is is almost hidden by the relatively strong image colour, DMax is superb. There's just a bit of GD to object to on some papers. On Harman FB AL glossy or Innova Fibaprint glossy and also some matte surfaces, this is as close to perfection as I've got. What issues remain I can easily overlook, and the colour printing is superb too. Sure, it doesn't have the absolute permanence of pure carbon printing, but it should outlive me by some margin given the Vivera inkset's stability. The HP isn't perfect by any means (it's a goddam inkjet!), it's just a different set of compromises that happens to suit me and may not match someone else's aspirations. I like what it does, especially the freedom from clogs given my pattern of intermittent use. That has been a major problem with all of the 4 Epsons I've owned and I'm delighted to see the back of it. However I think current Epsons are improved, so maybe this is not such a big deal. Best of all I can get excellent colour and B&W from one printer which was impossible a few years ago. But HP's not unique in that, I know quite a few very happy 3800 owners. It also uses ink very efficiently compared to every Epson I've owned, seemingly getting about 1.5x-2x as many prints from the same ink volume. There are some downsides eg question marks about long-term durability of the printer with some people having serial warranty replacements. Some people have head-crash problems with Harman in particular (curls when wetted by the ink) though I have not; and there are idiosyncrasies with the HP PS software which I avoid using Qimage. And Epson is more widely supported with a huge user base and paper mfrs fixed on the Epson market which perhaps means slightly worse paper compatibility with the HP (Ilford papers except Fiber Silk don't work well). But this is a tiny problem compared to my experiences with Cone and G4 inks, which worked well with very few papers I liked, and not at all with non-matte. There's an B9180 list at hp9100Series@yahoogroups.com for anyone who wants to know more. -- Regards Tony Sleep http://tonysleep.co.uk
2008-07-23 by Bill Morse
Hi Tony- Could you elaborate a little on how you use Quadtone and RGB? Thanks, Bill On Mon, Jul 21, 2008 at 7:46 AM, Tony Sleep <TonySleep@...> wrote: > > - B&W as RGB. For me this is the exciting and interesting bit about the > HP. I am able to quadtone images and print as RGB to get extremely close > to selenium-toned 1970's Agfa Record Rapid (before Agfa took out all the > noxious Cadmium and ruined it). That was my favourite paper of all time, > utterly sensual to print and look at. What metamerism there is is almost > hidden by the relatively strong image colour, DMax is superb. There's just > a bit of GD to object to on some papers. On Harman FB AL glossy or Innova > Fibaprint glossy and also some matte surfaces, this is as close to > perfection as I've got. What issues remain I can easily overlook, and the > colour printing is superb too. Sure, it doesn't have the absolute > permanence of pure carbon printing, but it should outlive me by some > margin given the Vivera inkset's stability. > > -- Regards, Bill Morse Wm. Morse Editions http://www.MorseEditions.com/ [Non-text portions of this message have been removed]
2008-07-24 by Tony Sleep
On 23/07/2008 Bill Morse wrote: > Could you elaborate a little on how you use Quadtone and RGB? Basically quadtone a greyscale image in PS, convert to sRGB, print as RGB. I started out using the quadtones from Ken Lee but keep adjusting them slightly. http://www.kenleegallery.com/html/tech/bronzeOld.htm Curve tweaks are usually necessary as they add density, especially in the shadows. Lately I've been selectively blending the quadtoned layer with a greyscale or tinted layer, to adjust the strength and extent of the effect more controllably. -- Regards Tony Sleep http://tonysleep.co.uk
