Peter,
> At work we have a 2200 with Cone neutral K7 inks.
> We'd like to replace the Cone inks with a good but
> less expensive option, and we're considering Paul's Eboni-6.
> Would we have to flush the K7 inks from the
> printer, including the parking pad?
I would recommend flushing.
> If so, how do we do this?
Basically water will do it. Windex on the pads is even more effective.
Some wetting agent that is compatible with the inks is good, but who
really knows what is in these things and what is compatible?
MIS has a cleaning fluid that they think is compatible with most, but I
don't really know if they've tested it with Jon's inks.
That's why I mixed the water + glycerol base. It's the most
universally compatible fluid with the most or what is needed besides
the wetting agent.
I actually inject a bit of Windex straight into the head to clean it
out. It's great for clogs and probably also for just changing inks.
The 1280 dyes were the only serious incompatibility issue we had, and
there once the pads were clean there was sufficiently little ink in the
head to cause much of a problem -- at least so the dogma went. I
usually just plugged in the MIS inks and rinsed the pads. It seemed to
work. I'd probably inject a little Windex today.
> ... we have a large stock of Photo Rag and German Etching.
> How well does Eboni-6 work with these papers?
See page 8 of http://www.paulroark.com/BW-Info/Eboni-6.pdf
Photo Rag (like it's sibllings), has a large warm split tone that is
not unlike that favored by some very good printers. Whether you like
it is subjective. I personally like the warmth for my people shots
and "southwestern" types of images. I prefer a more neutral or cooler
look for my landscape images, where I think clouds look best cooler.
For landscapes I prefer Premier Art Smooth BW, Condor BW, Moab Entrada
BW, and even old Brightcube Eclipse Satine (which is the paper I used
yesterday to make a 16 x 20" landscape print).
Hope this helps.
