Eboni-6 with the old piezography plug-in
2008-08-06 by arthurkrick
I have an Epson 1290 standing idle which I am considering bringing into use as a dedicated
B&W printer. I previously used this machine with a CIS set up and the Piezotone Warm Neutral
inks including Museum black. The machine ran with the original Piezography BW plug-in and
I was very happy with the results. However, the source for the inks in the UK closed down so
in time I  shut the system down and cleaned out the 1290. I am not wanting a variable tone
ability and am excited with what I am reading about Paul's new formulation which MIS have
on offer as Eboni-6. My question is would the old Piezography plug-in be usable with this
inkset in printing through my 1290 ?
Re: Eboni-6 with the old piezography plug-in
2008-08-06 by pr_roark
The old PiezoBW software would not work with Eboni-6 as it is
currently formulated.  However, the workflow for Eboni-6 using ICCs
made with QTR's Create-ICC program is, in my view, supperior to the
old Piezo rip in any case.  In addition to the modern workflow
being "color managed" for essentially automatic monitor relative
density matching, I believe you'll find it faster and having a better
dmax.
While the Epson driver by itself will probably produce good results
with Eboni-6, making an ICC only takes a flatbed scanner (as well as
the QTR program).  It makes a very nice workflow -- the one I use
most of the time now.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "arthurkrick"
Re: [Digital BW] Re: Eboni-6 with the old piezography plug-in
2008-08-06 by arthur.krick2@tiscali.co.uk
Hi Paul,
it is good to have such a direct and rapid response to my question and from "The Fountain Head"too !
I have a flatbed (Epson 750) to hand and I will shortly sport US$50 and download myself the QTR RIP. Then I will settle down with a moderate measure of scotch and a wet towel to work my way round mastering the ICC creation process.
thank you again,
Arthur  Get up to 33% off Norton Security only from Tiscali - http://www.tiscali.co.uk/securepc _______________________________________________
I've simplified my recommendations for making ICCs with a flatbed
scanner.
See http://www.paulroark.com/BW-Info/Making_B-W_ICCs-GrayCard.pdf
for my latest thoughts on that subject.
Also note the progression of workflow options for Eboni-6 at
http://www.paulroark.com/BW-Info/Eboni-6.pdf pages 3-5.
There I start with no ICC (just the Epson driver), then go to a
simple ICC with no curves, and finally to an ICC that includes an
embedded curve.  It's possible that the Epson driver with no ICC and
possibly a slight slider adjustment will make a print that is very
good.  At any rate, start simple.
Paul, Thank you for the Links which I will study closely. "Keep it Simple, Stupid"!  I think that maxim is generally a good one to follow so I'm grateful for anything that moves me in that direction. I have just 'phoned MIS and placed my order for Eboni-6 inks. Thank you once again for your guidance,
Arthur
Back To Basics
2008-08-07 by Ken Alexander
Hi Everyone,
I feel funny asking this after successfully printing
in black and white for so long, but I'm still trying
to get a firm grasp on what Dmax is.  My (probably
oversimplified) understanding is that it is the
maximum darkness (density?) that a given combination
of paper and ink can achieve.
What I still don't understand is:
- how is it measured?
- what units is Dmax expressed in, or is it a
dimensionless number?
I did try googling Dmax a while back but wasn't really
satisfied with what I found, especially regarding the
two questions above.
Any additional light you can shed would be
appreciated.
Ken
Re: Back To Basics
2008-08-07 by Louis Dina
Ken, comments are below your questions.
Lou
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Ken Alexander
<k.alexander@...> wrote:
> Hi Everyone,
That is correct.  Each printer/paper/ink combination has a maximum
black it can achieve (often called Dmax).  The paper and ink are
obvious contributors, but the printer can also have an impact.
Different dithering, resolution, number of passes, etc, can affect the
ability to achieve a solid black.  Too much ink, or incorrect
combinations of ink, can result in pooling, fogginess, and reduced Dmax.
Print Density is usually measured with a densitometer or a
spectrophotometer.  It is often expressed in density units, but also
in L* units(the L* component of Lab, ie, Lightness).  They are two
different ways of expressing the exact same Dmax.  Since Lab space is
often used as the universal translator for printer profiles, and most
spectros read Lab data, it is often used, but both units are widely
used.
A great place to learn more (and see a translation graph that equates
L* and density) visit http://www.BruceLindbloom.com.  Click the
"Calculators" link, and then "Companding Calculators".  If you click
density as the input and L* as the output (or vice versa) you will see
a graph that converts from one to the other.  You can also input
specific values to convert back and forth.  A density of 2.2, for
example, is equivalent to L* = 5.6994.  The calculator also lets you
see density expressed in Y units, or your choice of two different
gammas.  Pretty flexible.
Bruce also has a lot of articles, formulas and other information on
his site related to color, density, color management, etc.  It gets a
bit geeky fast, but it is loaded with tons of good information.
Re: [Digital BW] Re: Back To Basics
Thank you Lou.
This is excellent!  I'll go have a look at Bruce's
website this evening.
My next "Back to Basics" question was going to be
about Lab, but maybe I'll find my answers there.
Thanks again,
Ken
> Lou
> Ken Alexander
> > Hi Everyone,
> printing
> trying
> combination
> has a maximum
> and ink are
> an impact.
> etc, can affect the
> incorrect
> densitometer or a
> units, but also
>  They are two
> Since Lab space is
> profiles, and most
> units are widely
> used.
> really
> the
> graph that equates
>  Click the
> versa) you will see
> can also input
> density of 2.2, for
> two different
> information on
> information.
> Please visit the Group Homepage to check the Files,
> and other resources as they are often being updated.
> If you wish to receive no emails or just a daily
> digest, or you wish to unsubscribe, please edit your
> Membership preferences by visiting this same page.
> - As threads develop, trim off excess portions of
> earlier messages to keep them short.
> - Good manners are required at all time. No personal
> attacks or flames. Hostile, aggressive or
> argumentative users may be removed from the
> membership without notice.
> - Keep your posts and threads related to the group
> topic of digital B&W printing. Users who
> persistently make off-topic posts may be removed
> from the membership.
> - By posting on this forum you agree to abide by the
> group rules and guidelines, and to abide by the
> actions and decisions of the group Owner and
> Moderators. See \ufffdGroup Topic, Rules and Guidelines\ufffd
> in the Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE
> DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY
> UNDERSTAND AND AGREE THAT THE \ufffdOWNER\ufffd AND
> \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP
> SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT,
> INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY
> DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR
> LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER
> INTANGIBLE LOSSES (EVEN IF THE  \ufffdOWNER\ufffd AND
> HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH
> DAMAGES), RESULTING FROM: (i) THE USE OR THE
> INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO
> GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF
> YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR
> CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE
> PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING
> TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/join
>     (Yahoo! ID required)
mailto:DigitalBlackandWhiteThePrint-digest@yahoogroups.com
mailto:DigitalBlackandWhiteThePrint-fullfeatured@yahoogroups.com
