Adding subtle color to 3MK +PK+Glop on Harmon Gloss FB AI
2008-08-14 by jvircoe
For those who want to preserve the archival qualities of black and white printing that comes with Paul Roark's 3MK+PK+Glop workflow but would like to add some subtle color washes to selected parts of their images I have developed the following workflow that gives very nice results. Warning! this procedure requires a minimum of three passes through the printer for each image and is probably not something a black & white purist would want to consider but I think the results are worth it. Pass1 Selected tonal area of the image to receive the color wash. Pass2 Straight image print using Paul's workflow Pass3 overprint of pure glop/gloss optimiser across the entire image The Pass1 image is created in Photoshop by selecting the area of the image to receive color and filling the rest of the image with 100% white. The selected area is then lightened so that the maximum tone is 1-3K (ie very, very light). I use very simple QTR curves to mix MIS yellow and magenta that can print anything from a soft yellow, to sepia or soft crimson tones in the final print by varying the mix of the two color curves. As the image that is printed is extremely light, registration with the second pass is rarely an issue and the combined tonal value of the 2 separate passes is not obviously darker than a straight single pass print. I also tend to use the wash in the background rather than the foreground of my images so the tonality of the foreground is preserved. Pass2 and Pass3 are as per Paul's published procedure. The completed image can evolke old-world sepia tonality or warm selected parts of the image to provide additional interest/contrast. Of course you don't have to stick with just yellow and magenta. In fact it might be interesting to try Blue washes in skys etc. I use an Epson R1800 printer with the pizza wheel rollers removed. All of the inks are supplied by MIS. I print mainly landscape images. Hope this is of interest. cheers Jim
