--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "neil0968"
<neil0968@...> wrote:
> Thanks for your help Paul, its very much appreciated.
> I have another question I'm afraid. I'm about to order the Eboni
ink
> but notice there are a few references to Eboni on the inksupply
> website. Do I need "EB6 Carbon Monotone Matte Blk (Eboni)" for the
> Carbon 6 or have I picked the wrong one?
> Thanks again,
> Neil
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "pr_roark"
> <pr_roark@> wrote:
> > Photo Flo 600 is the large lab (non-consumer) version of Photo
Flo,
> > and is 3 times as concentrated as the 200. It has the same
wetting
> > agent. You would probably get the same results if you simply
used
> > less (1/3).
> > I'm not sure how much the additional glycol in the Photo Flo 200
> > matters. You'd end up with less of that also with the 600, but
> > offsetting this is that the 600's version of glocol is probably
> more
> > effective (though toxic).
> > I have some of the Ilford wetting agent but have not tested it.
My
> > guess is that it's about the same. I'd just try one of those and
> see
> > what works.
> > Paul
> > www.PaulRoark.com
> > <neil0968@> wrote:
> > > Thanks for the reply Paul.
> > > I cant find a source of Photoflo 200 in the UK but we can get
> hold
> > of
> > > Ilford Ilfotol wetting agent which is also a 1:200 working
> strength
> > > mix. Do you think this is worth a try? I can also find Photoflo
> 600
> > > but I seem to recall one of your articles/messages refers to
you
> > > using Photoflo 200.
> > > Many thanks again,
> > > Neil
> > > <pr_roark@> wrote:
> > > > >... which inkset would be best suited to an Epson 1290
> > > > > My concerns are really about clogging the nozzles which
> > > > > has been a problem on my printer, even with OEM inks, ...
> > > > > I would really like to go down the Carbon 6 route,
> > > > > mainly due to cost and and also having the satisifaction
> > > > > of mixing my own inks ...
> > > > > I'm just worried about clogged nozzles.
> > > > Carbon-6 is probably one of the inksets least likely to
clog.
> > > There is
> > > > no binder in it except for the residual from the Eboni, which
> is
> > > > relatively clog free.
> > > > If you give it a try, let us know how it works on the 1290.
> > > > Paul
> > > > www.PaulRoark.com
I have been using an Eboni 6 inkset in my 1280 for about
four months now and have not had a clogging problem. However,
I do try to run a nozzle check about once a week.
Tom Garrett
